That's what I thought. Was slight confused with this:
DIY - RNS510 Install
3) Satnav Antenna
The RNS510 comes with a satnav antenna which plugs into the back of the unit. It plugs into the blue socket. If you have a shark fin antenna installed on your car, this antenna won't be necessary as the shark fin can be used as the satnav antenna. The satnav antenna feeds up through the vents and can sit near top middle vent. The antenna however is also magnetic and can be attached to a small piece of metal for easier fitment.
