Results 1 to 1 of 1
Thread: CAN Errors after RCD330 Install
    Jan 2016
    Perth, WA
    After much reading through these threads, I purchased an RCD330 from RCD330.com and a cheapo RGB to composite converter from AliExpress. I believe that I have a lowline camera as I didn’t have any moving lines on the RNS510 when reversing.
    Removed the existing RNS510, disabled the 2E-Media Gateway, 37-Navigation and 77-Telephone in VCDS and unplugged the Bluetooth module under my driver’s seat. Fitted the RCD330 and all the head unit functions worked as expected.
    Another VCDS scan showed a few errors but I hadn’t installed the reverse camera module, so I continued as per the information in “RCD330+ OEM Camera Connection”.
    The camera appears to be receiving power, and the logo flips up when engaging reverse, but I receive a message on the head unit that says “The Rear View camera system is currently not available”.
    I attach the edited output from a VCDS scan (forum rules wouldn't allow me to attach everything) and would be grateful if anyone can shed any light on my problem.
    Cheers.
    Wednesday,26,February,2025,09:54:38:12409
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 24.7.1.0 (x64)
    Data version: 20240919 DS356.3
    www.Ross-Tech.com
    VIN: License Plate:
    Mileage: 181450km-RCD330+RVC Repair Order:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 14 15 16 17 19 25 42 44 46 52 56 62 69 72
    VIN: Mileage: 181450km-112747miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
    Component: BCM PQ35 M 103 0615
    Revision: 00103 AD
    Coding: 48180A3A8025F1C040080080340001E441510088536D896064 8000200040
    Shop #: WSC 01357 011 00200
    VCID: 356B24169C710F3E28-8060
    Subsystem 1 - Part No: 5K2 955 119
    Component: Wischer 02111 26 0512
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 011110 05 54 0403
    Coding: 0330AD
    Subsystem 3 - Part No: 1K8 951 171
    Component: DWA-Sensor 00 001 0104
    Subsystem 4 - Part No: 1K8 951 605 A
    Component: LIN BACKUP HO H11 9004
    No fault code found.
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
    Component: Lenks.Modul 007 0080
    Revision: -------- Serial number: 90440JK2000SY Dataset Number: 5K0953507AH D005
    Coding: 189A140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_A05.rod
    VCID: 76E9E31AC9F74426E1-8022
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H06 0010
    Serial number: 0162741
    Coding: 830000
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 5K6 920 871 HW: 5K6 920 871
    Component: KOMBI H20 0420
    Serial number: 00000000000000
    Coding: 170B01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 71E3D006A099631E34-8024
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 C HW: 1K0 907 951
    Component: J533 Gateway H37 0614
    Revision: H37 Serial number: 061110F1000251
    Coding: 350003
    VCID: 3065150263132A167B-8064
    2 Faults Found:
    01305 - Databus for Infotainment
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 20
    Mileage: 181454 km
    Time Indication: 0
    Date: 2019.07.20.
    Time: 09:22:35
    03272 - Control Module for Audio Interface
    Freeze Frame:
    Fault Status: 01110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 236
    Mileage: 181453 km
    Time Indication: 0
    Date: 2019.07.20.
    Time: 14:27:17
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
    Component: Radio 541 5614
    Revision: -------- Serial number: VWZZZ4R6215572
    Coding: 1E000440040005
    Shop #: WSC 21862 418 140358
    VCID: 468953DAF19794A6B1-8012
    3 Faults Found:
    00856 - Radio Antenna
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 236
    Mileage: 181454 km
    Time Indication: 0
    Date: 2019.07.20.
    Time: 09:05:38
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    02873 - Control Module for Back-Up Camera (J772)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 236
    Mileage: 181454 km
    Time Indication: 0
    Date: 2019.07.20.
    Time: 09:48:44
    End-------------------------(Elapsed Time: 02:49)--------------------------
