Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Can bus codes for current DSG gear
    Quote Originally Posted by An7on View Post
    Moved the seven segment display up to the gauge pod. Thanks to a lid from a deodorant can. Its a perfect 52mm
    Improvise, adapt, overcome
    Mar 2016
    Brisbane QLD
    Im interested in this. Trying to crack out the codes i need. So far ive got throttle pedal input, gear selection and now searching for rpm and gear selected. This is on a 2012 passat. Codes are different to yours. Trying to figure out what is what is really hard!!
    Feb 2008
    ACT
    Quote Originally Posted by Jwarnes71 View Post
    RPM you can pull from 0x35B bytes 2 and 3, formatted as follows:
    Code:
    long rpm = (byte3*256+byte2)/4;
    You mentioned you have gear selection so I'm not sure what the other item is you're looking for?
