Results 1 to 10 of 10
Thread: Can anyone help me get VIM for my Passat CC's RNS510?
    Sep 2006
    Anyone coming to GAD that can help me with this?
    Darko
    Mine:2012 MY12.5 Amarok |Natural Grey |RCD510|Premium Bluetooth
    Hers:2012 MY12.5 Passat TDI|White|RNS510|MDI|Premium Bluetooth|Park Assist 2 | Sports pack | Tints
    Aus
    You can get the custom firmware 40xx installed on your CC or install the Berto VIM file. Pls verify your RNS version 1st.
    http://www.vwwatercooled.org.au/foru...-nz-69790.html
    I've updated mine recently with the custom firmware & I've got access to VIM for my kid (not me) to watch cartoons.
    Current: | MY09 R36 | Dynaudio | RNS510 SatNav |
    Sep 2006
    Hey, I tried finding the secret menu but it didn't want to work! Will give it another go.
    Sep 2006
    Nope the setup button doesn't work all the radio service button shows is fm, am and dab.
    Jul 2010
    Based on the year model of your Passat and if it's a stock unit, then it should be ok to just install the Berto VIM mentioned above.
    However the better thread for all your RNS510 mod/upgrade needs is here:
    http://www.vwwatercooled.org.au/foru...tml#post830786
    From memory, the VIM CD also enables secret menu.
    If not, I think I do have the VIM version that does on my PC.
    MY11 Tiguan 147TSI (SOLD)
    Adelaide hills, SA
    If you were in SA I could do it for you in less than 5 minutes, without installing anything or removing the head unit.
    Sep 2006
    RNS510 Version C?
    Does it state firmware?
    Jul 2010
    That says Version C and firmware 1300.
    But that's what's on the disk you loaded into your unit for this pic above.
    Please clarify whether this is the readout from the Berto VIM CD?
    Nevertheless, it's got nothing to do with what version your unit is.
    Unfortunately, inserting a FW disk does not act like a diagnostic tool.
    In other words, that is not a readout from your unit.
    Anyhow, assuming it is the Berto VIM CD,what happens if you do follow through with this update and click OK?
    Have you tried it?
    Sep 2006
    Realised your right. Put in the bertoli vim cd and it went through the process and voila it worked. Vim works. The added bonus... Secret menu works and it's a b unit? (will have to put up a screen shot)
    Jul 2010
    You really can't tell what your unit is without VCDS.
    Even under secret menu, it will show the default unit version normally associated with that particular FW installed.
    For example, the below screen shot suggests it's a D unit, but it's definitely not!
    If yours is really a B unit, then the top right hand corner button will not be a 'star', but a speaker icon next to the letter 'i" instead:
    Basically all C unit and up (with LED screen) have the 'star' button instead.
    So much easier to tell by looking at this particular button!
