So I recently fitted an amp and aftermarket headunit to my sister's Polo. It works very well and sounds much better than the stock setup. However, whenever she drives the car, there's a buzzing sound and it seems to go in-sync with the revs, i.e. the higher the car revs, the more audible the buzzing sound becomes. Also, starting the car with the headunit on also gives a bit of trouble, as if the car is slightly struggling. However, there are no cut-outs or any other trouble.
I used a standard wiring kit to hook up the amp. I'm not quite sure but the power/ground cables provided were either 4ga or 8ga. Ground cable for the amp is about 40cm long. The headunit was adapted to the stock harness so I'm using the same wires that powered the old headunit. Same with the ground.
I think my problem is that the stock positive cables going from the battery to the starter/alternator are not rated high/thick enough. I didn't have this problem with my car as I upgraded all cables to 2ga/4ga when I did my installation. What do you guys think?
