Does anyone know of the location of the reverse wire on the bora. Or do i just steal it off the reverse lights?
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff| Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
New head unit has a cable for the reversing camera to automatically set to camera on reverse. Not required as i dont have a camera but may aswell install now whilst im installing unit.
I picked it up just next to the rear seat on the passenger side, was in the process of routing it back to the tail light when I found the loom there. So it would make sense that it runs all the way down the passenger side I would think, didn't actually look as I just tapped into it there.
Adam
2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
Previously -
2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
2002 Bora V5
Ah cool, did you just use a splice connector? Having good fun trying to find a fasica for a pioneer unit at the moment. Ordering from europe![]()
Yes, just a standard splice connector block thingy, never know what they are actually called! Please don't ask me what colour wire it was though as I can't remember!! I just used a multimeter to test the wires at the tail light to find out the wire colour then found that in the loom.
I am amazed a Pioneer head unit does not come with a facia, I have fitted a single DIN Pioneer in my previous car and that came with one, although I couldn't use it as it didn't fit.
Adam
Previously -
2002 Bora V5
Yeah the top of the line one aswell which is stupid but the double din throws it i think. Cheers tho think il leave it untill i get a camera
Which model is it? I just looked at the manual for the AVH-P3250BT on the Pioneer website and under the installation section it states:
I think your unit was missing this part from the box. A company like Pioneer would not supply a unit that could not be made to look mounted properly in a vehicle.NOTE
In some types of vehicles, discrepancy may occur between the unit and the dashboard. If this happens, use the supplied frame to fill the gap.
Pioneer Australia are very helpful, might be worth calling them to check if the unit should come with a frame.
Adam
Previously -
2002 Bora V5
Hmm im not sure. Apparently it doesnt come with one and pioneer dont make any. They use the screw in ones not the cage design. Oh well its coming in now anyway should hopefully look good. I found the wiring loom you talked about when putting the gps sensor on the back parcel shelf allthough i didnt connect it up. Cheers tho.
Cool, would be interested in seeing some photos when it is fitted and hearing your opinion of the unit.
Adam
Previously -
2002 Bora V5
