Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 90
Thread: Boost data in MFD
  1. #71
    Jul 2010
    Quote Originally Posted by aussietig View Post
    Don't know whether you recall, but a while back a request was made to you to scan and post up your coding for the doors on your Golf R since you have it working there.
    Quite frankly, you're definitely the right man for the job since you've also got a Tig as well.
    Anyhow are you able to answer that call now?
    Unfortunately member: Prodigy no longer has access to VCDS cable.
    So just wondering any member out there (with a Mk6 Golf and mirror dipping working) willing to help?
    That is, to scan & post up their door controller module's coding to help prove or dis-prove the door control module theory with the Tig.
    Should be module no. 52:
    MY11 Tiguan 147TSI (SOLD)
  2. #72
    Jan 2012
    Epping, NSW
    Quote Originally Posted by Prodigy View Post
    We have electric seats in our Tig but mirror dipping still doesn't work so it's not related to that. (have enabled it in VCDS but still nothing)
    I presume you have the little mirror adjust lever set to the Left mirror position? The auto dipping only will work on the left side mirror and only when the knob is set to the left side. (i.e. not centre or R).
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
  3. #73
    Jul 2010
    Quote Originally Posted by tonymy01 View Post
    Yes ... us Tig owners have tried and followed the instructions associated with this function. But no joy!
  4. #74
    Sep 2006
    Boost data in MFD
    Have u tries with vcds?? It's under central convenience. Sometime the mfd cannot change it due to its authorization rights in different modules.
    If anyone in Melbourne I am more than happy to meet up with u to try with vcds
  5. #75
    Quote Originally Posted by kinezo View Post
    There are a number of Tiguan owners that have tried... and failed. Aussietig suspects that there is a missing piece of hardware that stores/records the mirror position information.
    As Tiguan shares a lot of hardware with Golf 6 we believe there must be a difference in controller modules used somewhere which holds the mirror position data in the higher spec Golf 6. It seems that even the higher spec Tiguans don't get this up spec control module. At the moment we're not sure which one this is.
    So even though you can select the option in VCDS if the hardware isn't there to support the function then it won't work.
    We'll hopefully find out soon how well the Autopolar FIS+ does the mirror dipping.
    Jul 2010
    out of curiosity - does anyone have the vcds coding for the mirror down option?
    i doubt it will work on mine - but worth a shot i guess.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  7. #77
    Apr 2010
    I've already ticked the box in VCDS to turn on mirrow lowering, does nothing - don't have the right hardware
    See the very first pic here: The Official VWW VCDS Tweak Library
  8. #78
    Jan 2012
    Epping, NSW
    How about putting the mirror switch to the right instead of left (and setting it accordingly for reverse), maybe one other option needs to be set to tell the car it is RHD (this putting switch to right will prove it might be this issue)?
  9. #79
    Jan 2012
    good news. did some diagnostics for them and they support the skoda MFSW with the roll wheels. awesome bit of kit!
  10. #80
    Quote Originally Posted by zei20t View Post
    Cool. I saw there was a recent firmare update that came out for the roll wheels. These guys are pretty responsive to fixing any issues which is great.
    I know the white MFD is a new development for them (Red MFD is pretty stable/mature product). Probably is going to be worth keeping the USB interface easily accessible so you can download firmware updates when they come through.
