yes of course
turns out there is a new firmware literally just released. ive upgraded it, ill try installing again tomorrow. hope its not raining!
yes of course
This is what the white (but actually red) screen looks like. You can tell it apart from the true white screen because of the little arrow at the top left.
https://www.facebook.com/photo.php?f...type=3&theater
I hope you didn't have VCDS going at the same time. The Autopolar FIS and VCDS will conflict if you're trying to view the autopolar data at the same time as reading with VCDS. Both devices will try and control the bus. You can either have one or other operate but not both at once.
It sounds like this (or something similar) may be what's happening in your car.
bummer ... shame I dont have a car that will take this device anymore
anyhow... saw that some bits of the website is missing translations (translated in italics from Spanish) my community service
18 // Presión bomba combustible requerida (fuel pressure setpoint)
19 // Presión bomba combustible medida (fuel pressure at pump)
20 // Presión en rail de combustible (fuel pressure at rail)
21 // Presión pedal freno?? (brake pressure at pedal??)
22 // Presión bomba freno?? (brake pressure at abs pump??)
Having a Gap Year!!!!
what next?... what next?
I have an MY12 RS Octavia, its the white/colour screen.
yeah ive been reading the forums on there with problems other people have been having. ill try again tomorrow morning. might be a loose/faulty cable. ill meter them all out to make sure there is connectivity.
might be due to the octavia wheel controls. we have wheels instead of buttons for volume and menu up/down. i guess 'OK' is pushing the wheel.
You got rid of the B7 already?
I just was given the opportunity to walk away from my Novated TOT lease (lost nothing).... bought an NC1 MX5 to run around in whilst a new role settles down and I work out my fixed term contract... all good...
The DSG didn't fall out of it or nuthing the car was perfect ...
Not that you probably want to know about it now, however I found that you can purchase cheaper through Movitel - Polar FIS+ Advanced PF03 Interface [Upgradeable by USB] .
Including express DHL freight works out to EUR232 / AUD$284. This is the best deal available that I could find from the Autopolar resellers. You can save a few $ on freight by purchasing in quantity (though this doesn't reduce the unit price).
My god a whole thread about this Reverse mirror option..... I have it without using this module......its called using vcds and going into central convience and activating it via that......the only condition is u need rear parking sensors(factory) to be ale to do it. Nothing to do with seats......the rear parking sensor module actually sends out the signal to the mirror when activated by the reverse gear lever,
