Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 90
Thread: Boost data in MFD
  1. #41
    Jun 2008
    Ringwood, Victoria
    Have requested that they look into some other measuring blocks also, specifically the DSG blocks that measure clutch temperatures....
  2. #42
    What would be really neat is if the unit logged the data also... or stored it to a removable USB. But maybe I'm just asking a bit much now.
    Dec 2006
    Kilsyth, VIC
    FedEx man just turned up at my house...
    More photo's later
  4. #44
    Jan 2012
    nice!! installing tonight?
  5. #45
    Jun 2008
    Ringwood, Victoria
    Boost data in MFD
    Wow Aaron, he even delivered your change!
  6. #46
    Quote Originally Posted by The_Hawk View Post
    Can you let us know which seller you bought your unit from? movitel, polarteam or one of the other resellers?
    Delivery was pretty quick. Looks like there's a couple of units getting installed shortly.
    Dec 2006
    Kilsyth, VIC
    I bought it from Polarteam (the online shop on the original website).
    Also an install thread with lots of pics over here:
    http://www.vwwatercooled.com.au/foru...tsi-79213.html
  8. #48
    Jan 2012
    ok, i collected mine and went straight home to install!
    our gateway is in a different position (in the octavia), and its a little bit of a PITA to get to. but not impossible. i took photos.
    i got it all installed, thankfully i didnt put it all back together again. it worked, but then locked the MFD. im guessing because i have the factory bluetooth module using the 'phone' menu already, when i select it - locks up with some information from the FIS advanced. also gives me a whole load of errors that i had to reset via VCDS.
    i enabled the item in the gateway as per the installation instructions. didnt fix it
    The_Hawk, yours seemed to work. do you have satnav and/or factory bluetooth? and if so, which one?
    i have an RNS510, MDI and 9WZ(whatever the factory one is) BT module
  9. #49
    Dec 2006
    Kilsyth, VIC
    Boost data in MFD
    Yep, I have both Nav and Bluetooth. Did you upgrade the firmware in the device first??
    I didn't have to do any install through VCDS for mine... All automatic
  10. #50
    Jan 2012
    yup upgraded to latest version - while talking about upgrades. what a good way of upgrading!
    i tried with and without vcds programming. neither work. maybe my car has something newer?
    anyway ill post in their forum and put a VCDS log.
    glad yours worked first go!
