Page 7 of 24 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 239
Thread: BlueTooth related questions (all BT questions go in this thread only)
  1. #61
    Jun 2011
    Quote Originally Posted by GTD AYO View Post
    I had a similar but not identical problem with my MK6 GTD. It was impossible to activate the phone from either the touchscreen or the button on the steering wheel and the telephone had disappeared from the MFD completely. A quick diagnostic on the dealers computer resolved the problem. Was a very quick fix. Hope this helps.
    Thanks. Do you know what the diagnostic showed? And how they ended up fixing it?
    So this morning driving to work it was displaying the same symptoms as I described this morning.
    But then this afternoon driving home from work it's now starting just trying to connect to my iPhone but never succeeds. I tried turning off my bluetooth on my phone and turning back on, no change. Tried restarting the iphone no change. Turned bluetooth off my phone and it still keeps trying to connect to my phone. The Phone menu is just stuck on the searching for phone bit, no way for me to delete the pairing etc... Even just now I tried taking my wifes iPhone out (that is paired as well) and it still tried to connect to mine and wouldn't find hers. Something really not right with the bluetooth module/software in the golf. Friend has a vagcom cable so I'll try a scan to see if any error codes showing up.
  2. #62
    Arrawarra
    Bluetooth OBD II port dongle query
    Hey All,
    Can't seem to pair my newly purchased bluetooth OBD II dongle with my phone (for Torque Pro application). The red light comes on, indicating power, but when searching for nearby devices, my phone can't find it...
    Is there something else i have to do, or did i perhaps just get a dodgy one?
    Thanks!
  3. #63
    Mar 2012
    Glen Waverly, VIC
    Hey all,
    Here's one for you !
    A while back replaced RCD to RNS which had el chepo hands free kit from previous owner. Recently installed BT
    7P6 035 730J, all working fine (mounted BT module behind climate control), except BT streming only plays out of right side front and rear speakers. Iphone 5, same with mates Ipone 4s.
    Thru MDI, on 4 not working with 4-5 adaptor but, ok as with phone calls ie all speakers working. Any ideas from anyone ?
    All fuctions working ok as far as I can tell, MFSW etc
    12/09 Golf GTI
    Cant find anything via VAG COM
    Thanks in advane guys
    Mark VI Golf GTI - Carbon steel, DSG, Detroit's, Leather, Sunroof, Sat Nav, Reverse camera, R LED Taillights, APR Stage 1, Carbonio CAI, OSIR Vent pod, STRI DSD-SLM II boost gauge
  4. #64
    Aug 2011
    Quote Originally Posted by GtiGolf View Post
    Hey all,
    12/09 Golf GTI
    Are you sure phone calls via BT sound fine through all speakers? If it isn't there may be an issue with the Green phone plug at the back of your headunit (Left input may be loose) or the connector for your BT module.
    Volkswagen RNS 510 pin assignments | my-gti.com
    See mutlipin for telephone and check pin 5 and 11.
  5. #65
    Mar 2012
    Glen Waverly, VIC
    Thanks mate, yeah as far as I can tell works all good with phone calls.
    Removed the head unit yesterday and checked all connections again, all seems where it should be.
    Green phone plug ?
    Only have main wiring loom, and other stuff for sat nav camera.......
    Will prob end up just using MDi but would be nice if it all worked though.
    Townsville guy is at a loss as well. Apart from suggesting an older type BT module may work but would lose some functions.
    Which ones not sure !
  6. #66
    Oct 2010
    Southport, Queensland
    Hi everyone. I have a weird fault that has developed recently with my Bluetooth phone connection. I had an iPhone 4 IOS 5.??? and it all worked as it was supposed to. I upgraded my phone to an iPhone 4S and also upgraded my OS to OS6.0.1. Now the phone does not always ring through the car phone system (2011 GolfR RNS 510) and does not ring in the phone either so I miss calls. I also note that the remote control for the phone media player does not always work (Bluetooth streaming).
    I have read many forums and there are discussions re IOS 6.0.1 using Bluetooth 4. Perhaps the Golf has Bluetooth 3? I have tried resetting the phone. I tried re-pairing the phone. It seems to work briefly then it drops the link but appears connected as per normal. I have read that BT4 goes to low power mode after about 10-15mins. Perhaps this is related to the problem.
    I have the car booked in to a VW service centre for them to dig deeper. I am at a loss. Is it Apple of VW at fault?
    It is dangerous to hear the phone vibrate with an incoming call and look down to see what is happening. It should ring through the car system as it used to. I have run out of ideas re fixing this issue. I hope VW Aust. have a solution.
    Bockey
    2023 Tiguan R Driver
  7. #67
    Jun 2011
    Quote Originally Posted by Ferni View Post
    Ok so interestingly a few days after this my car battery died/drained overnight. Down to ~4volts. Jump started it, went for a drive and ever since then my bluetooth has been working perfectly. Very weird, makes me think the bluetooth module drained the battery but then by losing power it force it to reset and now it's fine?!?
  8. #68
    Oct 2010
    Re my BT problem with random disconnection. Dealer replaced the BT module with the latest version. So far so good.
  9. #69
    Apr 2010
    Did that take a lot of convincing or payment on your part? I assume your BT was factory fitted and dealers wouldn't be interested in helping out those of us who did a DIY retrofit. Good to hear there's a solution at least.
    Maybe I can try to sell my BT unit to an iPhone owner and put the funds toward a slightly newer revision.
  10. #70
    Nov 2012
    QLD
    Anyone who's used both the Kufatec 36495 (non premium version) and 730D (9W2) systems care to compare them? Particularly with a red screen MFD (I also have an RCD310 at present, pending battery drain issues, if they show themselves I'll go back to the RCD500).
    The VW system needs coding and seems to be fairly limited in operation whereas the the Kufatec option does not need coding and seems to present more features...
    But in saying that i'm fairly happy with just answering calls. I don't generally make calls while driving so accessing the phone book isn't a major thing for me (plus if i am honest my contacts are all over the place and need a serious cleanup). But I wonder if one has better sound quality for bluetooth audio streaming than the other?
