Originally Posted by
Bambazonke
Sounds like a 9w2 unit. A 9w7 identifies it self with "VW Phone" I have a 9w2 unit and it has the same ID as yours "VW UHF"
The easiest way to check which BT unit you have is find someone who has a VCDS cable and do an Autoscan this will tell you what unit you have without taking your dash a part. I reckon it will be a real bird's nest behind there with both a MDI and a BT unit installed there!
I am of the opinion that you will have to replace the whole kit as the loom from the BT module to the radio will probably be different (Tigger73 confirm?) also not sure if the 9w7 unit has an option for an external GSM aerial connection or will work without one? again Tigger to confirm
Your A2DP not working may be due coding of either the RCD 510, the BT unit or the MDI unit over riding the function. Very difficult to isolate the problem without knowing what type of BT unit it is!
