Bluetooth mic is integrated.
It's at the front on the left.
You can install an external mic but have to solder it to the internals
Install is very easy otherwise
Can't vouch for quality plenty of others have installed them. Ask them.
I'm an OEM only guy in general. Unless the aftermarket is clearly superior.
No the OEM solutions are more expensive.
They are cheap and cheerful though.
Hi everyone,
So much great information on here! Thanks for all the contributions. Hoping someone might be able to shed some light on my situation.
I recently bought a 2010 Tiguan and have just installed a bluetooth module (7P6035730F) as it had no bluetooth factory fitted. The car had the RNS-510 factory fitted with voice control so I didn't need to install the microphone.
After enabling the bluetooth in the VCDS I have been able to successfully pair my phone to play music and to make handsfree phone calls. The only issue I'm having is I am unable to use the RNS-510 controls to change track or to view the track information (artist, track name). The seller states the bluetooth module should provide these features so it must be an issue with my RNS510 (IT0035680C) as it's an older revision.
Is this correct that the RNS510 revision I have is incompatible with AVRCP or is there a firmware upgrade I can do? Otherwise is the bluetooth module I was sold the issue? I haven't been able to find the specific information I'm looking for on Ross-Tech's telephone retrofit page so any help you can provide me is much appreciated.
Thanks,
Hayden
Update the rns510 to the current version. 5238 (you will need to re load the maps).
Thanks Kamold,
Will do the update and let you know how I go. Cheers
The 5238 update worked wonderfully. Full Bluetooth control and song information. Only thing that doesn’t function well is the timeline bar of the song. Definitely something I can live with though. Thanks for your expertise Kamold!
Doesn't work with vbr files only CBR
