Page 20 of 24 FirstFirst ... 101819202122 ... LastLast
Results 191 to 200 of 239
Thread: BlueTooth related questions (all BT questions go in this thread only)
  1. #191
    Quote Originally Posted by night_flight View Post
    thanks kamold, my sunroof switch is buggered so I want to replace it so thought of doing the whole lot...VW says the whole panel has to be replaced @ about $500 can not just get sunroof rotary switch itself...From your experience when retrofitting these do you remember if the rotary switch can be swapped...If not I would replace the whole panel and have the dummy bluetooth buttons do nothing. as u said if u have to run an extra cable down to 9wz IT IS TOTALLY not worth it....
    I've never tried to replace the switch.
    It does look like it is available as a seperate part though...
    VW MK5 Jetta Golf Moonroof Sunroof Switch 2008-2010 Pearl Grey 1K0959613C | eBay
    But it might be cheaper to get a whole console from a wrecker
  2. #192
    Jan 2008
    Camperdown, NSW
    There is no firmware update available for that bluetooth module.
    Apart from unpairing and repairing the device you would probably have to try and test your phone with a different bluetooth module like a 9w7 or 9za, 9zz etc
    I've tried pairing and unpairing a couple of times.
    GTI | MY08 | Blue Graphite | DSG | Leather | Bi-Xenon | RNS510 |
  3. #193
    Quote Originally Posted by mark4323 View Post
    Try a different phone.
  4. #194
    Jan 2008
    Camperdown, NSW
    My previous phones have paired with no problem. Last being a Samsung S6.
  5. #195
    Apr 2010
    Adelaide, South Australia
    thanks again mate
    GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
  6. #196
    Jan 2008
    Camperdown, NSW
    duplicate
  7. #197
    Jan 2008
    Camperdown, NSW
    I realised the phone is connecting with the bluetooth. I can make and receive calls via the MFD, it just isn't connecting with the RNS510
  8. #198
    Jan 2008
    Camperdown, NSW
    Does anyone have experience with this kit? If I already have a 9w3 what work is required for install of this kit?
    Bluetooth KIT 3C8035730E - Retrofit - Newest Version for Red Dot Matrix FIS
  9. #199
    Jan 2018
    Azerbaijan, Baku
    Hi All. Recently installed premium BT 3C8 035 730C with rSap support. The issue is that sometimes I see Premium label on MFA+, but sometimes not. Second one is that sometimes when I connect to vehicle's BT, mobile data on my Samsung note 5 phone is switched off, but sometimes keep working. Has anybody faced similar issues?
  10. #200
    Mar 2018
    Hey all,
    Where is best place to get a BT module 5k0 035 730 F or equivalent please?
    I have a 5k0 035 730 B module under the drivers seat that I would like to upgrade.
    Thanks in advance.
