![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
kamold
Would need to have the additional wires run from the overhead console down the a pillar and into the Bluetooth module.
Then it would need to be coded.
To me it seems the effort to reward ratio seems pretty high...
thanks kamold, my sunroof switch is buggered so I want to replace it so thought of doing the whole lot...VW says the whole panel has to be replaced @ about $500 can not just get sunroof rotary switch itself...From your experience when retrofitting these do you remember if the rotary switch can be swapped...If not I would replace the whole panel and have the dummy bluetooth buttons do nothing. as u said if u have to run an extra cable down to 9wz IT IS TOTALLY not worth it....
GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
