Page 18 of 24 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 239
Thread: BlueTooth related questions (all BT questions go in this thread only)
  1. #171
    Jul 2010
    Quote Originally Posted by tom_12_24 View Post
    I currently have a RCD 510 (Bosch 5K0 035 190 (non a or b)) and Novero 9w2 (1K8 051 730 B) (dealer fitted). I purchased a 9w7 (5K0 035 730 F SW 2902 HW: H09) from another forum member (who says it was working in their car).
    I have tried a direct swap of the two units but the 9w7 doesn't appear to be working, when i turn on the car there are no discoverable bluetooth devices on my phone?
    Does anybody have any ideas how to get it to work?
    Thanks, Tom
    u need to initiate a "phone search" from the car. this can be found in phone menu via the mfd.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  2. #172
    Jun 2012
    Quote Originally Posted by dArK5HaD0w View Post
    I had a suspicion that might be the case. I assume that having the phone menu on the MFD needs to be activated? Looks like i might need to track down someone in brisbane with VCDS. Thanks
    Mk6 Golf GTI | Carbon Steel Grey | Single Clutch Human Controlled 6 speed transmission | 5DR
  3. #173
    Apr 2015
    Brsbane QLD Australia
    I might be around midday sunday mate. Norman park 4170.
    DARKHORSE DEVELOPMENTS
    BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
    BRISBANE/GOLDCOAST/IPSWICH
    www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
  4. #174
    May 2011
    Cronulla, NSW
    Hi Guys,
    I have a VW/Skoda 9WZ Premium Bluetooth module 5N0035730D that I'd be looking at swapping for a recent 9W7 (as I don't use the RSAP function) honestly I haven't kept up with what the pick of the vw bluetooth options are these days so if this is completely unreasonable request (or if I should be looking for something other than a 9w7) feel free to let me know. is there anyone here that would be interested?
    Skoda Octavia RS TSI Liftback MY11 - Race Blue
  5. #175
    Dec 2015
    NSW
    Hi forum
    In past months I've needed to "reset" the bluetooth module 3 times.
    Wot causes this annoying repeated failure, and how can it be avoided ?
    Yes, locating the BT module (an RF transmitting device) so close to the driver's body seems to be an unusual design decision (aka mistake), but thats a separate issue.
  6. #176
    More information required.
    Which bt module?
    Why do you need to reset the bt module and what exactly do you mean by reset?
    What head unit and firmware is it connected to?
    Sent from my HTC One_M8 using Tapatalk
  7. #177
    Dec 2015
    NSW
    I'm not sure what BT module or headunit. Its stock equipment in Mk VI Golf TDi.
    I'll do some research for exact details.
    Symptoms as follows :
    The phone menu sometimes disappears from the dashboard display.
    To fix this failure, I learned to disconnect the BT module (under driver's seat), start the engine for 10 seconds, switch off, reconnect the BT module, then restart engine, phone menu re-appears and works as intended.
    I call this disconnect-reconnect dance, a "BT reset".
  8. #178
    OK that sounds like an actual physical issue. As in cabling harness.
    A scan with vcds would confirm if the bt module is not being directed periodically.
    Then I'd be looking at the harness and unit itself for possible issues with a loose pin in the connector block.
    If still under warranty I would take it to your dealer to handle.
  9. #179
    Dec 2015
    NSW
    Thanks for the advice and feedback. 'tis appreciated.
    Next time it fails, I'll go see George at VW Village and let him work his magic.
    Current : 2017 Mk7 Golf R (most options) || 2012 Golf Mk6 TDi (few options)
    Gone : 2004 Bora V6 4Motion (few klms, all options)
  10. #180
    I've got an RCD 510(Delphi)+9w2 in my 2007 Jetta and I've never had phone book functionality and I just assumed it was a limitation of the 9w2. Today when reading the classifieds I saw that someone has a 9w7 and RCD 510 working with phone book (albeit with display issues). If I swap in the 9w7 would I immediately have the phone book feature or would I need to recode ? Is it possible that the RCD 510 simply doesn't support the phone book? I've read that with the 9w2 it is possible to have a phone book but only with the newer MFD possibly. Would someone please enlighten me?
