Page 13 of 24 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 239
Thread: BlueTooth related questions (all BT questions go in this thread only)
  1. #121
    Dec 2013
    Bundoora, Victoria
    Bluetooth problems!! Help!!
    Hey guys!
    So my bluetooth is working fine in that I can connect to my car, play music, answer calls and dial numbers BUT i cant save any preset "favourite numbers", cant see my recent calls, dialled numbers etc. Is this normal or is my bluetooth playing up? Also the microphone button on the steering wheel doesnt do anything?? I tried to reset to factory bluetooth settings and it didnt, so i tried deleting the paired devices one at a time but it didnt do that either.
    I ask because I only got the car a couple of months ago and have never had these functions. I thought I could figure it out myself but i cant. HELP!!
    If its relevant all, I have a 2010 Golf GTI with RCD510 head unit.
    Thanks in advance!
  2. #122
    Confused newbie
    All,
    I've read through the preceeding pages but I can't work out what BT is installed in my wifes 2012 cabrio. I'm trying to work this out for a probable RNS510 install later on. The cabrio has the factory RCD310 and BT install. The MFD shows VW PHONE on startup, and has phonebook and A2DP functions. My assumption is that it is a 9W7, but I know it is bad policy to assume things.
    Can someone decode the following and let me know what BT setup I have, and if it will integrate with an RNS510. (will it work with all the RNS510 models?)
    VCDS shows the following:
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
    Component: Radio RCD310 042 0082
    Revision: 01000001 Serial number: VWZ1Z2M4207xxx
    Coding: 01000400020008
    Shop #: WSC 00040 040 00001
    VCID: 72EBD4D5ADC7D38E9D3-8027
    and
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
    Component: TELEFON H09 2902
    Revision: 1B001001 Serial number: 00007661509xxx
    Coding: 0A01000000010101
    Shop #: WSC 01383 790 00003
    ASAM Dataset: EV_UHVNA A01719
    ROD: EV_UHVNA.rod
    VCID: 2643F885598FFF2EC1B-8073
    Ian B
    '12 Golf Cab'
  3. #123
    Jul 2010
    Turramurra, NSW
    Hey guys, I just bought a 9w7 module to replace the older version (9w3?) in my MY12 Polo GTI (has manual AC controls + RCD 510). I was under the impression that it is simple swap based on what I have read and seen (images and videos).
    I tried looking for the module under the driver's seat but can't find it...it has the storage compartment. Could the module be behind it? i.e. I need to remove the drawer to access it or is it behind the RCD 510? Assuming the 9w7 can fit instead of the 9w3, can someone enlighten me as to where can I find this bluetooth module?
    If this requires new wiring and stuff, then I am stuffed Am a complete noob in wiring / electronics and such.
    Thanks in advance.
  4. #124
    Mar 2007
    Melbourne, Vic
    Hi guys,
    I'm looking to buy a 9w7 bluetooth module to replace the 1K8051730D module (I'm guessing looks like the one in this post VW Bluetooth Module Part Number - 1K8 051 730 D - As new!) in my partners Polo 77TSI.
    Can anyone tell me if the harness connectors on these modules are the same or will I have to order the wiring harness as well?
    Also if I go down the path of ordering the full kit will the module with foam cover fit properly under the drivers seat in the Polo (like it does in the Golf/Octavia etc)?
  5. #125
    Mar 2007
    Melbourne, Vic
    Ok I think I've answered my own question with the right combination of search terms in Google. I found a few references to people replacing Volk L bluetooth modules with 9w7 modules and the wiring being plug and play. I'll find out for myself in a few weeks.
  6. #126
    Jun 2012
    A couple of questions that I can't seem to find the answer for despite lots of . I currently have a RCD 510 (Bosch 5K0 035 190 (non a or b)) and Novero 9w2 (1K8 051 730 B) and was looking to upgrade to either 9w7 or 9zz.
    I understand the 9w7 is plug and play compatible and i won't have change all my wiring. But I can't find out if 9zz is compatible with the same wiring (of course with the addition of the GSM antenna)?
    Secondly does anyone know if the Revision M version on 9w7 (7P6 035 730 M) and C or D version of 9zz (3C8 035 730 C / D) compatible with the non A or B revisions of the RCD 510. (Meaning free of any issues with the phonebook)?
    Mk6 Golf GTI | Carbon Steel Grey | Single Clutch Human Controlled 6 speed transmission | 5DR
  7. #127
    Canberra
    No streaming from iphone5s
    Hello
    I'm not up to date with BT and RCD510.
    I have a my 12.5 amarok that originally came with an RCD200.
    I've updated to a RCD510- 5KO 035 190 B
    The blue tooth module is a 5KO 035 730 E- dealer fitted? Or factory, it's on top of the transmission tunnel.
    The phone works and voice control but the BT music icon is grey and it won't stream music.
    What do I need to do to get it to stream music from my phone.
    Regards
    Steve
  8. #128
    Canberra
    Bump, anyone?
  9. #129
    Pacific Paradise QLD
    No Steam Maybe its not hot enough ROFL
  10. #130
    May 2009
    Canberra
    Hi All
    Few months ago I upgrade the Head unit of my 09 tiguan from RCD310 to Bosch RCD510. That works fine, then after few months I bought a Parrot CK3000 evolution bluetooth with 2 connect so I can use the button on my steering wheel. I ask my mechanic to open the gateway for hand free, and that all (box ticked) I try to connect the kit today. I follow the manual how to connect it and all as well. The button on my steering wheel is working, making call or picking up calls. My problem now is.
    1. It doesn't cut the music when I try to make or received calls.
    2. My phone pair with the bluetooth but I can't hear any sound coming out to the speakers when I make or received calls.
    3. The people on the other line can't hear me and I can't hear them.
    Have I missed anything, do I need to recode the head unit because I change from rcd310 to RCD510?
    Thanks Lincoln
    2009 Tiguan TDI and 2007 Passat TDI
