Hello all,
I just received a 9W7 Bluetooth unit (7P6 035 730L) and am looking for some direction as to how to install the unit in the factory position of under the passenger seat. The car is a MY2010 Passat CC, if that makes any difference.
I have removed the RNS-510 as well as the Climatronic controls but there is a small black box doodad (not sure what exactly, but I suspect something to do with adaptive cruise control as there is a sticker with ACC-something on it) already installed behind the climate controls. Unfortunately, that means the Bluetooth unit doesn't fit in the spot that all the guides point to. Just wiring up the harness to the RNS-510 while out of the dash shows the unit works as would be expected without VCDS coding being done yet.
Looking around on the Internet, I've only managed to find guides showing how to do a clean/retrofit install behind the Climatronic unit or to do an upgrade from an earlier under-seat factory fitted version, but no new installations under the seat.
The bit I'm most unsure about is how to route the wiring from the RNS-510 to the seat, and am a bit leery of randomly removing bits of trim in a new car to find out myself.
Thanks in advance for any assistance received.
