Page 23 of 24 FirstFirst ... 1321222324 LastLast
Results 221 to 230 of 239
Thread: BlueTooth related questions (all BT questions go in this thread only)
  1. #221
    Quote Originally Posted by oldstuff View Post
    Hi All,
    I am a newby on here and have a 2009 147 Tiguan it has Red MFC. It has a phone button on the radio & steering wheel but no bluetooth function. So looks like I need a new head unit if I want to take phone calls via bluetooth. So that is my main aim, if I could get something that does that & has Android car play then that would be a bonus.
    Any suggestions prefer simpler options ( like me ) if that is possible.
    Cheers Stewart
    Your best best bet would be to get an rcd330g.
    Has integrated Bluetooth and carplay/android auto support.
  2. #222
    Oct 2018
    Milperra, NSW
    Hi Kamold,
    Are they hard to install ? What about a mic for the blue tooth ?
    I did a search for RCD330G on ebay plenty of stuff from China, are these OK ?
    Sorry for all the questions, just on a leaning curve.
    Stewart
  3. #223
    Bluetooth mic is integrated.
    It's at the front on the left.
    You can install an external mic but have to solder it to the internals
    Install is very easy otherwise
    Can't vouch for quality plenty of others have installed them. Ask them.
    I'm an OEM only guy in general. Unless the aftermarket is clearly superior.
  4. #224
    Oct 2018
    Milperra, NSW
    So are these available OEM as well as all the Chinese jobs ?
  5. #225
    No the OEM solutions are more expensive.
    They are cheap and cheerful though.
  6. #226
    Nov 2018
    Hi everyone,
    So much great information on here! Thanks for all the contributions. Hoping someone might be able to shed some light on my situation.
    I recently bought a 2010 Tiguan and have just installed a bluetooth module (7P6035730F) as it had no bluetooth factory fitted. The car had the RNS-510 factory fitted with voice control so I didn't need to install the microphone.
    After enabling the bluetooth in the VCDS I have been able to successfully pair my phone to play music and to make handsfree phone calls. The only issue I'm having is I am unable to use the RNS-510 controls to change track or to view the track information (artist, track name). The seller states the bluetooth module should provide these features so it must be an issue with my RNS510 (IT0035680C) as it's an older revision.
    Is this correct that the RNS510 revision I have is incompatible with AVRCP or is there a firmware upgrade I can do? Otherwise is the bluetooth module I was sold the issue? I haven't been able to find the specific information I'm looking for on Ross-Tech's telephone retrofit page so any help you can provide me is much appreciated.
    Thanks,
    Hayden
  7. #227
    Update the rns510 to the current version. 5238 (you will need to re load the maps).
  8. #228
    Nov 2018
    Thanks Kamold,
    Will do the update and let you know how I go. Cheers
  9. #229
    Nov 2018
    The 5238 update worked wonderfully. Full Bluetooth control and song information. Only thing that doesn’t function well is the timeline bar of the song. Definitely something I can live with though. Thanks for your expertise Kamold!
  10. #230
    Doesn't work with vbr files only CBR
