Page 16 of 24 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 239
Thread: BlueTooth related questions (all BT questions go in this thread only)
  1. #151
    Jul 2015
    Hi, I have 2010 VW Polo (MY11) 1.2tsi 6R comfortline with a RCD310 stereo (Guessing from photos I've seen of that unit) and buttons on the steering wheel for accepting calls and voice command etc.. But I'm pretty sure that it does not have a Bluetooth module installed. Do you know which Bluetooth module I should get for my car or how I can find out which one to get? I've read a few threads but it's all a bit confusing to me. Or would I be better off replacing the stereo with a RNS510 (cost-wise). I just need to be able to answer/reject calls and have the sound come through the car speakers. And preferably have it fitted by someone as I am a noob at all of this and don't wanna damage the car! Can anyone help me out??
    Any help is much appreciated. Thanks in advance!!
  2. #152
    Apr 2015
    Brsbane QLD Australia
    If you just want to answer calls then a 9w7 bt kit is ok and it will also stream music. But if you want to make and answer calls and have a phonebook display you will need a 9w7 kit. If you add a RCD510 OR RNS510 then you will also get phone book display on the radio unit.
    DARKHORSE DEVELOPMENTS
    BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
    BRISBANE/GOLDCOAST/IPSWICH
    www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
  3. #153
    Mindarie, Perth (WA)
    Quote Originally Posted by Darkhorse Developments View Post
    If you just want to answer calls then a 9w2 bt kit is ok and it will also stream music. But if you want to make and answer calls and have a phonebook display you will need a 9w7 kit. If you add a RCD510 OR RNS510 then you will also get phone book display on the radio unit.
    fixed for you
  4. #154
    Jul 2015
    Adelaide, South Australia
    Need help with 9W7 Bluetooth with RCD510 on gti mk6
    Hi Guy,
    I have a vw golf gti mk6 and i believe my bluetooth was 9w2 and i tried to change it to a 9w7 but it doesnt seem to be working.
    it comes up on the radio and the MFD but it keeps trying to connect to previous owners phone and i am unable to get it to display in the bluetooth section on the mobile to connect to. so basically it wont show up on my mobile and i cant search for the phone to connect to. i try my mates 9w7 module in my car and it connects up straight away so i dont know what the problem is. could it be coding? can some one help.
    this is my auto scan.
    Chassis Type: 1K (7N0)
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Malfunction 1010
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
    Component: BCM PQ35 H 103 0615
    Revision: 00103 AD
    Coding: 48180ABAE837F1C0408800803400092441550088737D8D6064 8000200040
    Shop #: WSC 01357 011 00200
    VCID: 3851FA728B72A4E196F-806D
    Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer 29091 26 0512
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 011010 05 54 0403
    Coding: 0330AD
    Subsystem 3 - Part No: 1K8 951 171
    Component: DWA-Sensor 00 001 0104
    Subsystem 4 - Part No: 1K8 951 605 A
    Component: LIN BACKUP HO H11 9004
    No fault code found.
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
    Component: AirbagVW10 013 0613
    Serial number: 003G5RAEJH2R
    Coding: 00003956
    Shop #: WSC 30020 959 100527
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
    ROD: EV_AirbaVW10SMEVW360_SK35.rod
    VCID: 3147C756600875A9D11-8064
    Crash sensor for side airbag; driver side:
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME26627258ZZZV
    Crash sensor for side airbag; front passenger side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME7D693158ZZZ3
    Crash sensor for side airbag; rear; driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3512QSME1A137173ZZZO
    Crash sensor for side airbag; rear; passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3522QSME3A24701AZZZT
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
    Component: Lenks.Modul 007 0080
    Revision: -------- Serial number: 90422JID000MA
    Coding: 1892140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_SE36.rod
    VCID: 76CD344AC9E61291443-8023
    Multi Function Steering Wheel Control Module:
    Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H05 0010
    Serial number: 0136652
    Coding: 830000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K6 920 871 HW: 5K6 920 871
    Component: KOMBI H20 0420
    Serial number: 00000000000000
    Coding: 170F01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
    VCID: 71C70756A08835A9911-8024
    Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
    Part No SW: 7N0 907 530 HW: 1K0 907 951
    Component: J533 Gateway H27 5603
    Revision: H27 Serial number: 031010F2001919
    Coding: ED817F0600060200000003
    Shop #: WSC 50620 822 175810
    VCID: 6DFF1B2674B0D149B59-8038
    1 Fault Found:
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 59
    Reset counter: 180
    Mileage: 72323 km
    Time Indication: 0
    Date: 2015.07.19
    Time: 18:03:28
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H20 0420
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
    VCID: 6AF5103A8D5EC671D0B-803F
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
    Component: Tuer-SG 009 2120
    Coding: 0000692
    VCID: 3147C756A80875A9D11-8064
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 74 3001
    Revision: 00H17000
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
    Coding: 0000692
    VCID: 3245C85AAD0E4EB1A8B-8067
    Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0148
    Revision: 00H04000 Serial number:
    Coding: 1443164
    VCID: 3449CE42571A4081BA7-8061
    Subsystem 1 - Part No: 7L6 941 329 B
    Component: AFS-Lst.-Modul l 0004
    Coding: 00000022
    Subsystem 2 - Part No: 7L6 941 329 B
    Component: AFS-Lst.-Modul r 0004
    Coding: 00000022
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 190 HW: 5K0 035 190
    Component: Radio RCD510 041 0167
    Revision: 00000001 Serial number: VWZ1Z3K3569519
    Coding: 0500044004
    VCID: 62E5781A7D6E9E3118B-8037
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 58
    Reset counter: 180
    Mileage: 72323 km
    Time Indication: 0
    Date: 2015.07.19
    Time: 18:05:12
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
    Component: Tuer-SG 007 2101
    Coding: 0000144
    Shop #: WSC 01357 011 1012552
    VCID: 354FF3465C6059898D9-8060
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
    Coding: 0000144
    VCID: 364DF44A41665291843-8063
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 B HW: 7P6 035 730 B
    Component: TELEFON H05 0440
    Revision: 1B001001 Serial number: 00007668647795
    Coding: 0A01000000010101
    ASAM Dataset: UHVNA A01007
    ROD: UHVNA.rod
    1 Fault Found:
    9458195 - Control Module for Cellular Telephone
    B1052 13 [009] - Open Circuit
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 132
    Mileage: 72323 km
    Date: 2015.07.19
    Time: 18:06:43
  5. #155
    Camberwell, Vic
    So are you saying you have two 9w7 - one you bought new and doesn't work and one that you took our of a friends car, plugged it in to yours and it did work?
    If so, I would check the number of the back of the unit and post up here as it would seem as if the one you have is not compatible and you have the wrong version...
    2010 R36 (MY10.5), Biscay Blue, RNS510, MDI, Electric tailgate, sunroof, Superchips remap - SOLD
    2016 Octavia VRS wagon, moon white, Tech Pack, 18" black pack, electric boot, panoramic sunroof, Bluefin
  6. #156
    It looks like your coding for your BT unit might be wrong.
    Use the long coding helper to fix it.
    You need to remove telephone baseplate from coding if you don't have one (old school pins under the arm rest to hold the phone and connect to the car) and also remove keypad preparation if you don't have that.
  7. #157
    Jul 2015
    Quote Originally Posted by slipshot View Post
    yes I have 2x 9W7 bluetooth. One I bought second hand and the other I borrowed my mates 9W7 which is also second hand. The 9W7 I have is 7P6 035 730 B
  8. #158
    Jul 2015
    Sorry I am very new to this and dont know what you mean. can you explain more simpler?
    what is the long coding helper?
    also what do i need to do to remove telephone baseplate from coding?
  9. #159
    You need someone to hook up a VCDS cable and correct the configuration of the bt module.
    There is plenty of info on basic vcds coding I can't post specific instructions right now.
    Sent from my HTC One M8 using Tapatalk
  10. #160
    Jul 2015
    I have the cable. what setting do I need to change?
