All,
I've read through the preceeding pages but I can't work out what BT is installed in my wifes 2012 cabrio. I'm trying to work this out for a probable RNS510 install later on. The cabrio has the factory RCD310 and BT install. The MFD shows VW PHONE on startup, and has phonebook and A2DP functions. My assumption is that it is a 9W7, but I know it is bad policy to assume things.
Can someone decode the following and let me know what BT setup I have, and if it will integrate with an RNS510. (will it work with all the RNS510 models?)
VCDS shows the following:
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: VWZ1Z2M4207xxx
Coding: 01000400020008
Shop #: WSC 00040 040 00001
VCID: 72EBD4D5ADC7D38E9D3-8027
and
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661509xxx
Coding: 0A01000000010101
Shop #: WSC 01383 790 00003
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 2643F885598FFF2EC1B-8073
