Page 11 of 24 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 239
Thread: BlueTooth related questions (all BT questions go in this thread only)
  1. #101
    Apr 2012
    Quote Originally Posted by unrealshots View Post
    for your first problem, try to delete the connection and re-create it... if the iPhone has had a recent update to IOS 7 it may have screwed up the bluetooth streaming...
    2nd issue, there is an option in the setup of the RNS510 to set the levels that come from the MDI...
    Ok I'll give the re-syncing ago.
    As for the MDI the levels are fine it's just very distorted.
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  2. #102
    Apr 2012
    The re-syncing didn't work in fact it made it worse I can't now change tracks on the steering wheel.
    What should my audio in VCDs be set as?
  3. #103
    Quote Originally Posted by Bassik View Post
    Hey all,
    I recently just upgraded to a Golf from Polo ... noticed that now every time I get in the car I have to press pause and then un-pause to start playing my music.
    Does anyone have an suggestions.
    Thanks
    Got the same issue - Polo to Golf, and now I have to press pause and play to get it to work. It's not the iPhone, as I just switched to an Android and getting the same issue...
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  4. #104
    Oct 2012
    Melbourne, Victoria
    Quote Originally Posted by sVWatt View Post
    I have this as well on my R36 (although I don't think the car makes a difference).
    I find it only happens when I've been playing with my phone and my music app has been pushed into the foreground.
    Have you enabled 'bluetooth autoplay' in the RNS options?
    Biscay Blue Volkswagen R36 MY09
  5. #105
    Melbourne, Australia
    Question 77TSI RCD510 Bluetooth Retrofit
    Hey guys and gals,
    Just upgraded to the RCD510 Bosch unit in my 77TSI Golf and I'm now looking at adding bluetooth. Just wondering how hard it would be (if possible) to add a 9w7 or 9w2 unit in my car and how i connect it to the head unit, if anyone has done this or could shed some light on it would be great. Now that P plate laws have changed again my Blueant unit is useless and will look for a more integrated approach. I understand that steering wheel controls and MDI won't exist but even having to press on screen to pick up/hang up is better than nothing.
    Cheers,
    Ryan
    2011 Mk6 Golf 77TSI CW | 12" Rockford Fosgate Subwoofer | RCD510 | Golf .:R MFSW | GTI Rear Bumper | GTI Tail Lights | Mk6 GTI Exhaust
  6. #106
    Very easy install.
    Buy the kit from forum sponsor JKU, or carsystems.pl and it has the right wiring harness included.
    Alternatively you can get a Dension BT gateway which has MDI type functionality thrown in for less than the 9w7..
  7. #107
    Thanks for that!
    Will there be much/any coding needed? Just so I know whether I need someone with VCDS to give me a hand or not.
  8. #108
    All those BT modules listed in above post should install themselves into the canbus gateway installation list automagically.
    In some instances some coding is required to gain full functionality, but basic functionality will just work.
  9. #109
  10. #110
    Apr 2012
    Hey did anyone solve the Bluetooth auto play in the RNS510 because I have to press play on my iphone each time I get in the car, so annoying, previously in the polo it would auto play as soon as the car is on.
    PS I haven't found the auto Bluetooth option either?
