Page 10 of 24 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 239
Thread: BlueTooth related questions (all BT questions go in this thread only)
  1. #91
    Jan 2011
    Brisbane - QLD
    You only need the code if you connect the RNS510 into a different car. I've disconnected my one (from eBay) plenty of times, have also had battery disconnected a few times, I only needed the code the first time I retrofitted it.
    Thanks!
    a quick scan just now revealed that the Tiguan does already have a bluetooth! albeit the dumb dumb do minimal version silly me...
    Address 77: Telephone (J73 Labels: 1K8-035-730.clb
    Part No SW: 1K8 051 730 D HW: 1K8 051 730 D
    Component: Telefon H03 6900
    Revision: 00003000 Serial number: 00000A07781485
    Coding: 402120
    Shop #: WSC 22690 959 14172
    VCID: 287127225BD4905849C
    No fault code found.
    I guess I will just sell the kit when it arrives tomorrow.. or install it in my GTI
    MINI Cooper S Clubman - FWD
  2. #92
    Jan 2013
    Hi!
    Does anyone have proper installation instruction with pictures how to run the main bluetooth cable between the RNS510 and the bluetooth module under the drivers seat in a Tiguan?
    MY18 VW Tiguan Comfortline
  3. #93
    Aug 2011
    Quote Originally Posted by PeteC View Post
    Hi!
    You don't have to run it to under the seat, generally theres enough space on top of the glovebox
  4. #94
    Adelaide hills, SA
    Quote Originally Posted by readerr0r View Post
    ...and why not do it properly and install it where the manufacturer installs them as well? It's not that difficult to run the wiring to under the seat location.
  5. #95
    Jan 2013
    How can I change the default 4 digit PIN code to connect my phone to the Bluetooth unit (9w7)? By default is 0000.
    Plus if I am connected to the 9w7 unit, the sound of SMSs will not come through the speakers (only the ringing) so if I have the phone in my pocket I will not know when I receive a message. Is there a way to enable the SMS sound while I am connected to the Bluetooth unit?
  6. #96
    Jan 2013
    Anyone?
  7. #97
    May 2013
    Bathurst NSW
    Does anyone know if there is a difference between the harness for the 9w2 and 9w7 bluetooth modules? I need a harness for a 9w2 unit I got with a 2nd hand stereo but can't find one anywhere. I've seen the 9w7 cables though and I'm hoping that one might work.
  8. #98
    Aug 2009
    Melbourne, Vic
    Does anyone have a PDF users manual for the VW BT Gateway? Most of it is self explanatory with the 7P6 035 730L when controlling it from my MFD. I did find this 2010 Bluetooth Gateway for VW manual. Whilst it is for a US Mobridge / parrot device, it seems to operate in much the same manner. Can any one do better than this and produce an up to date user manual that contains newer features?
  9. #99
    Apr 2012
    MDI and Bluetooth issues on RNS-510
    Hey all,
    I recently just upgraded to a Golf from Polo and had to swap over the bluetooth model because the one in the Polo displayed track names etc. Anyways after swapping over the unit I noticed that now every time I get in the car I have to press pause and then un-pause to start playing my music. Previously in the Polo as soon as my phone synced it would start streaming music again. Does anyone know how to fix this? I have VCDs as well.
    Second issue that whenever I plug my phone into the MDI plug the sound is dramatically decreased, almost like 56kbps. I have changed some things in VCDs but nothing to my knowledge that would effect this. I did however upgrade the firmware on my RNS-510.
    Does anyone have an suggestions.
    Thanks
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  10. #100
    May 2013
    for your first problem, try to delete the connection and re-create it... if the iPhone has had a recent update to IOS 7 it may have screwed up the bluetooth streaming...
    2nd issue, there is an option in the setup of the RNS510 to set the levels that come from the MDI...
