hi there mate, looks as if youve done a good job there...
i would suggest however making up some MDF rings to mount the speakers on and ditching the standard items as this would give a much more dense/solid surface to mount the speakers on...
dont be too scared with taking the door apart, its rather straight forward. just remember to support the window with some tape to hold it up while you remove the regulator (its attached to the door skin)
theres plenty of DIY guides on VW Vortex if youwant more information
as for the under seat mounting of amps and subs, you will find that there is next to no room under there, not even enough for a small amp. best and only place to mount this sort fo thing would be the boot.
keep up the good work!
dan
1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
