Yes mostly. Though because the video is in Spanish it's a little hard to follow.
Instead of right mirror you select the left one (as that's the one you need to see the curb on anyway) and set the "normal" and "dipped" positions. I did play around with the settings from OFF/Manual/Automatic and settled on Auto (not sure if this is to do with DSG/manual transmission or what??) but after a bit I got the mirror to dip when selecting revese gear.
I'm not sure if you need to or not but the mirror selector switch is on the left mirror - haven't tried setting it in other positions when selecting reverse to see if it still works in other setting positions.
Will have to disable it and then work out the "procedure" to enable it again - maybe even make a video with the menus in English
I thought manual referred to the fact you had to have the switch set to L before it would dip when you put the car in reverse, where as automatic would always dip.
But that was in the instructions of the polar fis guys and clear English is not one of their strong points
