Mirror dipping works in the Tiguan
I have updated the online Shreadsheet of FIS+ info:
Added Car Specific Installation information to help users know where the CANBUS is located, and how it can be accessed, and where to store the FIS+ box. I added the following rows: Vehicle (RHD/LHD), CANBUS module Location, FIS+/CANBUS Cable Installation acces via, Auto-Polar FIS+ box located
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
did you follow the video they posted in your thread?
Yes mostly. Though because the video is in Spanish it's a little hard to follow.
Instead of right mirror you select the left one (as that's the one you need to see the curb on anyway) and set the "normal" and "dipped" positions. I did play around with the settings from OFF/Manual/Automatic and settled on Auto (not sure if this is to do with DSG/manual transmission or what??) but after a bit I got the mirror to dip when selecting revese gear.
I'm not sure if you need to or not but the mirror selector switch is on the left mirror - haven't tried setting it in other positions when selecting reverse to see if it still works in other setting positions.
Will have to disable it and then work out the "procedure" to enable it again - maybe even make a video with the menus in English
hmmm I tried all that. except the mirror switch position. so thanks! ill try that tonight
I'll admit I left my mirror switch on R as well, hoping both would dip (since that's what I usually do myself)
Since I reverse downhill on a steep & curved driveway I like having both dipped, that's the main reason.
the only thing that will 'annoy' me about that is the fact that in winter I leave the switch in the heater position. ill have to remember to switch it when im reverse parking. cant have everything though I guess!
