Thanks Tigger73 for the Group Buy
Recieved mine Friday at work.
And again when wanting to install some goodies onto the car it is another 35degC+ day! LOL
My Mk5 Jetta was not all to plan.
I tried going through to the CANBUS controller from the inside but I had another contoller in front of it and I could not push it out of the way to get to the CANBUS connector... so I went in from the rain tray.
IMO going from the top through the rain tray was much much easier. There are only 2 stumbling blocks...
1) getting the wiper arms off the spindla after you undo the nut - trick is to grab the wiper blade with right hand and hold it just off the glass then with the left hand grab the spring loaded hinge and gently push down then pull up again and again and it will walk off the spindle.
2) Getting the wiper mechanism out - trick is to take out the torx bolts. move the wiper mechanism towards the center of car till you can drop the side part down under the mounting location, then shift it back up under the windscreen towards the side of the car. Now rotate the front of the mechanism up and the center part will now slide up and out then just gently wiggle the wiper mechanism up and out towards the center of the car.
What I also did was put some split loom tube over the FIS+ connection cables so it does not rub and wear against anything under the dash.
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
