Page 7 of 17 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 162
Thread: Autopolar FIS+ Advanced Install
  1. #61
    Quote Originally Posted by jamesatfish View Post
    Success!
    I ended up fully erasing the firmware using the downloadable Updater exe, then updating back to 0.3.0b6. Tested this morning and it works as it should.
    Good news.
    Suspect you may have initially had red MFD firmware trying to talk to a white MFD - probably too excited to get the unit in the car...
    Now to configure and sort out what data I want to display.
    What I'd really like is actual speed plus distance to empty on the same page, but it doesn't look like the fuel data can be displayed?
    Decisions, decisions how to configure the 6 displays. Like a little kid in a lolly shop.
    Will have to ask the Autopolar guys about making some of the information that is in the "standard" MFD screens available for the FIS+ screens so that you can configure your own displays how you want them.
    Jun 2011
    Autopolar FIS Advanced Install (Mk6 Golf 118TSI)
    Great progress! Keen for screen shots of each menu...
    Getting exciting!
    Golf R | UG | DSG | 19" Silver | ACC | Leather | Viezu vRace | FIS+ Advanced | View car diary thread
  3. #63
    Feb 2008
    ACT
    Success!
    Spoke too soon.
    The testing above was with the car parked. The minute I drove it the display disappeared from the MFD and I lost the RNS-related menus again.
    I checked all the connections and all were tight, so there might be a faulty cable or internal connector somewhere that has an intermittent connection.
    I've pulled it out completely now - will check on the autopolar forums to see what's the best next step.
  4. #64
    Jan 2012
    you may need to do the online updater.
    i just did an update to 0.3.0W (for white/colour display) and its working perfectly. there are no 0.3.0XX anymore as 0.3.0 is now a full version.
    and i think it has 5 screens of info, and yes 4 lines on each.
    for those of you who have requests, they are very open to suggestions and generally happy to make changes. however, they prioritise fixes and corrections to previous functions.
  5. #65
    Jun 2011
    Quote Originally Posted by zei20t View Post
    they seem to have a very active developer team.
  6. #66
    Apr 2010
    Was that update posted today? Only just updated mine yesterday and was about to install it.
  7. #67
    Jun 2011
    http://www.auto-polar.com/forum/show...=5329#post5329
    Looks like 23 Nov.
  8. #68
    Apr 2010
    Just had a look for it via my sunglasses cubby hole. Good news is I can see the unit where it's supposed to be. Bad news I could barely fit a pair of tongs through that gap, let alone an arm or two. Not sure what the point of removing the fuse cover was either since that gave no extra light or access. Ominous clouds overhead so will have to postpone until tomorrow.
  9. #69
    Adelaide hills, SA
    Go back to my post with the link to MK5 canbus and look at how to swing that relay carrier awy to get enough room to work there.
  10. #70
    Jan 2012
    i wonder if its the same as my octavia?
    behind the relay holder is the gateway yes? i just reached up and unplugged it.
    where are people putting the USB cable when not in use? ive chucked mine in the holder thingo below the headlight selector. was looking for better locations......
