Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 151 to 160 of 162
Thread: Autopolar FIS+ Advanced Install
  1. #151
    Apr 2010
    Some good tips there. I keep forgetting to retry this feature so hopefully tomorrow I'll get around to it.
  2. #152
    May 2011
    Sydney,NSW
    re: Autopolar FIS+ Advanced Install
    Thanks tigger will give this a shot tomorrow.
  3. #153
    Apr 2010
  4. #154
    Nov 2005
    Sydney NSW
    Nice info thread about the FIS on VWGolf.net
    Polar FIS+ Advance Interface
    Welcome to 3 weeks ago
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
  5. #155
    Apr 2010
    huh? I've onwed my unit for 3 weeks already. The same info is here, but just a bit messier
  6. #156
    Apr 2010
    Had a stuff around today for 15 minutes and I can confirm that on my normal Mk6 Golf, the PolarFIS is able to automatically dip my left mirror when I select reverse gear. I just haven't got it working 100% how I want it to yet.
    So if anyone was wondering if missing hardware was an issue, it appears not to be the case.
    Quote Originally Posted by eltiobarbas View Post
    Hi, the Alternate mode its use in vehicles that not working in normal mode.
    The offset have +- mode, it's used to adjust the height of the mirror when you have configure and no return to the desire position.
    In Manual mode, the mirror lowers when you select Reverse gear, and the Automatic mode, the mirror lowers if you have the blink and reverse gear. So if you have automatic mode activated and reverse gear the mirror not move, you need to use the blink to work.
    Regards
    (I assume by blink they mean indicate, i.e. it will only work when you indicate say to reverse parallel park, but lower every other time you reverse without turning.)
  7. #157
    huh? I've owned my unit for 3 weeks already. The same info is here, but just a bit messier
    I've fixed up this issue - post #3 now contains instructions for Golf Mk5, Golf Mk6, Jetta Mk5 and Tiguan plus instructions for the mirror dipping.
    If there's any new installation stuff I'll look to include it in post #3 so it's all right up the front - save people having to hunt through the whole thread looking for the right info.
    A couple of things:
    1) mirror dipping only works on passenger mirror (at the moment anyway).
    2) you can choose to adjust both mirrors at the same time (manually) - there's an option under mirrors Alt. mode which allows you to move both mirrors together. If you select passenger mirror any adjustment will only move the passenger mirror. If you select the drivers mirror then both will move together when this option is selected.
    Apr 2010
    Really? They just said the driver side mirror isn't wired via the gateway so they can't move it.
  10. #160
    That very well may be the case. Mirror dipping on drivers mirror doesn't work for me either so that would make sense.
    I just didn't know if it was a software or hardware limitation so if it's hardware that's pretty much terminal for getting mirror dipping on drivers mirror going.
    So I'm afraid it's going to be a manual job - but at least you can select to have both mirrors tilt at the same time.
