Page 13 of 17 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 162
Thread: Autopolar FIS+ Advanced Install
  1. #121
    Jun 2011
    ^ that's odd. all I can see is for the 0.3.1 updates here.
    Golf R | UG | DSG | 19" Silver | ACC | Leather | Viezu vRace | FIS+ Advanced | View car diary thread
  2. #122
    Apr 2010
    The 3.2b update is supposed to fix the problem that I reported (check the link from my previous post)
  3. #123
    OK after much searching I've finally located the CANBUS gateway in my Tiguan. It's in behind the glove box - requires removal of the glovebox and it is very simple install once this is removed.
    Glovebox removal instructions (thanks to bambazonke):
    1. Remove 5 torx screws (3 at top and 2 at the bottom)
    2. Unclip side panel by wedging upwards and then pulling out from rubber door seal
    3. Wedge carefully out cubby hole light and unplug
    4. Slide glove box out and then unclip rubber tube from air con to cool glove box
    5. Unclip glove box light switch from the back of the glove box near the air con tube as discussed in step 4
    6. Unclip open/close contact switch from centre back of glove box housing
    7. Assembly is in reverse order.
    Then you'll see that gateway connector right in front of you:
    I've stashed the Autopolar FIS+ box just under the removable trim in the footwell so there's only a wing nut to undo and easy access to the unit for future firmware upgrades.
    Last edited by tigger73; 09-12-2012 at 05:03 PM. Reason: added additional step to remove switch
    Jun 2011
    ^ excellent. another good hint for future Tiguan installers...
    ok, so what's the verdict Damien - working well?
  5. #125
    Quote Originally Posted by boltor View Post
    At this stage it looks to be working right out of the box. I've gone through all the parameters I have available and am now going to sit down and work out which parameters to put on each screen.
    I've asked autopolar to get back to me with a procedure/list of vehicles that support mirror dipping feature so this is the next thing on my "hit list".
    If I can get this feature going it will be great.
    May 2011
    Sydney,NSW
    Hi guys installed my fis and I am getting ESP:error.
    Had battery unplugged while installing.
  7. #127
    Apr 2010
    Disconnecting the battery in itself causes the ESP error - it's nothing to worry about and disappears when you drive for a few seconds
  8. #128
    May 2011
    Sydney,NSW
    re: Autopolar FIS+ Advanced Install
    Thanks. thought I might have dislodged something while fiddling around for in the cubby hole for the box
  9. #129
    Yes mine also threw a fault which cleared after driving. I think this is a side-effect of disconnecting the battery.
    Apr 2010
    3 methods of accessing the gateway now - I think they should all appear in the first post and remove 118TSI from the heading
