Page 12 of 17 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 162
Thread: Autopolar FIS+ Advanced Install
  1. #111
    Did you select the "upgrade" menu on FIS+ to do the firmware upgrade? Unit must have this function active to upgrade while still in the car. If you have taken it out then there may be a problem with the unit.
    Either way I recommend posting tech issues on the Autopolar forum as this is where the developers hang out. They are pretty good at sorting out these types of issues.
  2. #112
    Apr 2010
    Well if I can't see the FIS in the MFD (car is off btw anyway) I assume it thinks it's not connected to the car so I should be able to update in this configuration.
    Plus I'm trying to work out how on earth to access it via the cubby hole. I can twist & move the relay to the left (in front of the FIS box), and I can wriggle the gateway around a little, and from the motion I think it slides up out of a bracket, but I'm struggling to pull that off. Which way am I supposed to push or pull at it?
    I already have a thread on the other forums.
  3. #113
    Adelaide hills, SA
    re: Autopolar FIS+ Advanced Install
    No clips, just lifts out and move towards you.
    Sent from my GT-N8000
  4. #114
    Apr 2010
    Thanks, struggling with the lift up bit then... it feels like the gateway is anchored on its left side.
    Success, saw a tab on the front of it and pried a long flat head screwdriver for leverage to get it out.
    Ok got the FIS box out now and it's allowed me to update to 3.1. Guess I just have to reconnect it all and see if the car will return to normal.
  5. #115
    Apr 2010
    Everything's back to normal now... besides the gateway not being exactly where it should be (running out of daylight)
    Took the module out, updated from 3.0 to 3.1 ok, found out cable that plugs into the FIS was starting to split at the plug in (it's not a great plug design and could easily be unplugged (although I'm not sure if that was a result of my tugging on it when trying to remove it). Reconnected it all and shoved it all back in, and the FIS box is just sitting in the cubby hole compartment where my sunglasses used to be.
  6. #116
    Apr 2010
    RNS510 Diagnostics mode
    Looks like I'm not the only one with that problem
    and also a quicker resolution is to disconnect the battery or gateway fuse instead of spending 2 hours trying to disconnect everything and reconnect it
  7. #117
    Jan 2012
    its probably good you checked the plugs anyway.
    glad its working for you again.
    when you perform an upgrade (major) it will do the diagnostics thing to the RNS510. mine did it first time. never done it since.
  8. #118
    Well I can confirm that the Tiguan gateway is not in the same spot as Mk6 Golf.
    First went from below under the dash - removed the fuses etc but couldn't locate it going blind. So decided to go from top where you can actually see. Removed the wipers etc and confirmed that the area is bare.... just a few cables running around.
    Looked at the side of the footwell as this was suggested also - not there either
    So next job is to start investigating behind the glovebox.
    Adelaide hills, SA
    Look also for a different colour of the plug, it could be blue and it well could be behind the glovebox, look above the line where the pedals would be in the LHD Tig. That's where the canbus is in the LHD Q7.
  10. #120
    May 2011
    Sydney,NSW
    Just got around to updating mine. Saw that there is a 0.3.2b update, but can't find change log.
    Any ideas?
