Not all good after all, reinstalled the wiper arm and then realizing
I put the left on the right and right on the left lol now can't get them off till tomorrow when my mechanic shop is open lol
All good now went to my mechanic and he used a ball joint pulley to take it off, he said vw are a PITA to do simple things like this.
Might also go down to the local supercheap to see if I can source the control arm removal tool thingy. If its not too pricey will buy one, so if anyone is reading this in the Newcastle area and needing to borrow it I am more than happy to give you a hand or you can borrow the tool too. Still playing around with the parameter options. What do other people set (screen1, 3 etc)? Also what's the best way to measure boost etc
Good to hear you got it going after all that.
I have 5 screens set up. First screen has speed, RPM, fuel litres and oil temp, which I use most of the time. Then I have one screen with temps, one with torque/power, one with boost parameters and the last with a mix of others.
For details on the boost parameters please refer earlier post: Boost Pressure - Detailed Information
The boost data (and in fact all the engine parameters) is taken from the ECU and not a separate boost tap. So you'll only get the measurements from the existing sensors.
My unit died this weekend - blue tooth would not work, left hand steering wheel buttons would not work, navigation would commence as per usual but no voice instructions during the journey and if you missed a turn there is no route recalculation - plus the entire RNS shuts down every ~20 minutes
Removing the Auto Polar FIS solved the problem (it was warm when I removed it)
It's a little disappointing, not even 12 months old
(So glad to have hands free phone working again)
