Page 19 of 20 FirstFirst ... 917181920 LastLast
Results 181 to 190 of 198
Thread: Auto-Polar FIS+ Advanced - Complete Guide
  1. #181
    Nov 2012
    Newcastle nsw
    All good now went to my mechanic and he used a ball joint pulley to take it off, he said vw are a PITA to do simple things like this.
  2. #182
    Nov 2012
    Newcastle nsw
    Not all good after all, reinstalled the wiper arm and then realizing
    I put the left on the right and right on the left lol now can't get them off till tomorrow when my mechanic shop is open lol
  3. #183
    Quote Originally Posted by Orrgazmo1986 View Post
    ....but did you get it working?
    Nov 2012
    Newcastle nsw
    Might also go down to the local supercheap to see if I can source the control arm removal tool thingy. If its not too pricey will buy one, so if anyone is reading this in the Newcastle area and needing to borrow it I am more than happy to give you a hand or you can borrow the tool too. Still playing around with the parameter options. What do other people set (screen1, 3 etc)? Also what's the best way to measure boost etc
  5. #185
    Good to hear you got it going after all that.
    I have 5 screens set up. First screen has speed, RPM, fuel litres and oil temp, which I use most of the time. Then I have one screen with temps, one with torque/power, one with boost parameters and the last with a mix of others.
    For details on the boost parameters please refer earlier post: Boost Pressure - Detailed Information
    The boost data (and in fact all the engine parameters) is taken from the ECU and not a separate boost tap. So you'll only get the measurements from the existing sensors.
    Jun 2011
    Reposting here from the AutoPolar forum - hopefully this makes some sense:
    TURBO PRESSURE parameter (extend info)
    Hi to all AutoPolar users,
    Due to receiving questions about this parameter, we will provide an explanation to try to clear all doubts.
    If you have any other questions, please post all your concerns, and we will complete this FAQ.
    How do I need to configure my PolarFIS to read turbo pressure correctly??
    To make a proper turbo reading pressure, normally is not necessary to configure anything in your PolarFIS unit.
    There is a configuration inside the unit that automatically selects the best option.
    However, there's a few models in which this automatic function doesn't work correctly.
    This guide will help you to identify if this is the case for you.
    These are available options in the pressure configution menu:
    - AUTOMATIC : PolarFIS will select the best option for your vehicle automatically. RECOMMENDED !! (by default)
    - INFORT X1 : To obtain the turbo pressure from the infortainment bus.
    - INFORT X2 : To obtain the turbo pressure from the infortainment bus. The reading is multiplied by 2 (only vehicles in which the bus only shows half pressure).
    - DIAGNOSIS : To obtain the turbo pressure from the diagnostics bus, for vehicles that the other options don't work.
    What values does the PolarFIS show in my screen ?? I not have idea ...
    The value that PolarFIS displays is the result of substracting the barometric pressure from the boost pressure read from the bus.
    This is due to the boost pressure sensor indicating the absolute pressure (BOOST+BAROMETRIC)
    But, sometimes I see negative values, why does this happen??
    Normally with the engine at idle, there must be some vacuum in the intake manifold, so tehe pressure reading will be negative (around -5 to -15 mbar or -0.07 to -0.2 PSI), this is normal.
    However, in some models there's no negative readings and with engine at idle the reading is 0 mbar or PSI, we can't do anything about this because the data is read directly from the Diagnostics bus of the engine ecu.
    A small negative reading as indicated is normal, however if you have a reading less than -100 mbar or -1.4 PSI it means that boost is not reading correctly.
    In that case, you must enter in the Polar FIS configuration menu, and select SCREEN->VISUALIZATION->ADVANCED->BOOST OPTIONS and choose the option INFORT. x2.
    This is due to in some cars, pressure read from infortainment is divided by 2.
    If the problem persists or you have no reading of boost pressure, enter in the same menu and choose DIAGNOSTICS option.
    Yeah I had found that but didn't explain which one is requested vs actual (with or without !)... pretty sure it's without.
    Also saw boost hit 23+ PSI at a glance last night...
  7. #187
    Quote Originally Posted by Ferni View Post
    Requested is the "!boost" from memory.
    Nov 2005
    Sydney NSW
    I concur.
  9. #189
    Dec 2012
    Sutherland Shire, Sydney
    My unit died this weekend - blue tooth would not work, left hand steering wheel buttons would not work, navigation would commence as per usual but no voice instructions during the journey and if you missed a turn there is no route recalculation - plus the entire RNS shuts down every ~20 minutes
    Removing the Auto Polar FIS solved the problem (it was warm when I removed it)
    It's a little disappointing, not even 12 months old
    (So glad to have hands free phone working again)
  10. #190
    Quote Originally Posted by Martin View Post
    Is it dead or did it just get locked? Power cycle will generally solve this.
