Page 18 of 20 FirstFirst ... 81617181920 LastLast
Results 171 to 180 of 198
Thread: Auto-Polar FIS+ Advanced - Complete Guide
  1. #171
    Quote Originally Posted by Ferni View Post
    I'm assuming !Boost is requested and Boost is actual?
    The !Boost i see in negative values (which is kind of what i expected due to vacuum), but the Boost value seems more realistic.. although holding 2-3psi while cruising on a flat freeway at 100-110k/h is a bit suprising... I wouldn't expect any boost pressure when cruising like that... Is that an inaccurate reading? I'm noticing about 18psi when on full boost with maybe a spike to 19-20 on the way... I assume thats normal for standard golf R?
    As for Engine Code, do you mean my Engine ECU code? I grabbed it from the info screen on the AutoPolar - 1K8907115D01F ...
    Damien - I'm only new to this thread and Autopolar but thanks as well
    Reposting here from the AutoPolar forum - hopefully this makes some sense:
    TURBO PRESSURE parameter (extend info)
    Hi to all AutoPolar users,
    Due to receiving questions about this parameter, we will provide an explanation to try to clear all doubts.
    If you have any other questions, please post all your concerns, and we will complete this FAQ.
    How do I need to configure my PolarFIS to read turbo pressure correctly??
    To make a proper turbo reading pressure, normally is not necessary to configure anything in your PolarFIS unit.
    There is a configuration inside the unit that automatically selects the best option.
    However, there's a few models in which this automatic function doesn't work correctly.
    This guide will help you to identify if this is the case for you.
    These are available options in the pressure configution menu:
    - AUTOMATIC : PolarFIS will select the best option for your vehicle automatically. RECOMMENDED !! (by default)
    - INFORT X1 : To obtain the turbo pressure from the infortainment bus.
    - INFORT X2 : To obtain the turbo pressure from the infortainment bus. The reading is multiplied by 2 (only vehicles in which the bus only shows half pressure).
    - DIAGNOSIS : To obtain the turbo pressure from the diagnostics bus, for vehicles that the other options don't work.
    What values does the PolarFIS show in my screen ?? I not have idea ...
    The value that PolarFIS displays is the result of substracting the barometric pressure from the boost pressure read from the bus.
    This is due to the boost pressure sensor indicating the absolute pressure (BOOST+BAROMETRIC)
    But, sometimes I see negative values, why does this happen??
    Normally with the engine at idle, there must be some vacuum in the intake manifold, so tehe pressure reading will be negative (around -5 to -15 mbar or -0.07 to -0.2 PSI), this is normal.
    However, in some models there's no negative readings and with engine at idle the reading is 0 mbar or PSI, we can't do anything about this because the data is read directly from the Diagnostics bus of the engine ecu.
    A small negative reading as indicated is normal, however if you have a reading less than -100 mbar or -1.4 PSI it means that boost is not reading correctly.
    In that case, you must enter in the Polar FIS configuration menu, and select SCREEN->VISUALIZATION->ADVANCED->BOOST OPTIONS and choose the option INFORT. x2.
    This is due to in some cars, pressure read from infortainment is divided by 2.
    If the problem persists or you have no reading of boost pressure, enter in the same menu and choose DIAGNOSTICS option.
    Jan 2012
    after the upgrade to 0.4.1, my mirror drop feature is working very well!
  3. #173
    Nov 2012
    Newcastle nsw
    Is there a trick in roving the wiper arms in mk6 golf r? I have removed the 2 nuts but the control arms will not budge. Been pulling and tugging but still will not come loose.
    Regards
    Orr
  4. #174
    Quote Originally Posted by Orrgazmo1986 View Post
    Regards
    Orr
    They are spring loaded when you have the wipers down one the windscreen. Suggest trying to "park" your wipers and then lift your wiper arms so that they are in pointing up.
    Not sure if this will solve your problem but I found if you take the tension off the spring pushing the wiper against the windscreen that this made things easier.
    Nov 2012
    Newcastle nsw
    What do you mean 'park' in the service position ie standing up or laying down? Being able to see them when standing
    I'm front of the car or not being able to see them when in front of the car, not sure
    If that makes semse
  6. #176
    Jan 2012
    turn on ignition. turn off ignition. press the wiper stalk down once within 30 seconds of taking the key out.
    that's the service position.
  7. #177
    Quote Originally Posted by zei20t View Post
    And once you've done this you can lift your wiper blades off the windscreen so they are sticking straigt up.
    I found if I took off the tension from the wiper it was easier to get it off.
    Nov 2012
    Newcastle nsw
    I've tried that but the arms will still not
    come off. Also have tried removing the wipers from the arms. Sorry to sound like a noob.
  9. #179
    I have heard of others having challenges - seems that some are harder to get off than others.
    You could try asking in the tuning section as some of the tuners often need to pull of the wipers/rain tray to get to the ECU on some cars.
    They may have some suggestions that could help.
    All else fails go via the dash.
    Dec 2009
    Kew, VIC
    I've sometimes had to use a bearing puller when the arms are frozen on (usual cause is corrosion.)
    Carefully applied heat might also help.
