Auto-Polar FIS+ Advanced - Complete Guide
Originally Posted by
Ferni
Cool once in 9 months isn't bad, hopefully i was just unlucky... I'll keep an eye on it.
What's the difference between "Boost" and "!Boost" ?
Also i'm not convinced the Exhaust temp is reading correct, can someone else check that?
! Does not mean not!
One is requested the other is actual.
With exhaust you have to compare with VCDS and what is labelled for your ecu code. Other wise have an external temp gauge to compare it with. Post your engine code so someone else with same ecu can compare your temps.
I know I have a few egt and cat temps that don't seem correct and can only put it down to mixed up labeling of the temp due to having a uncommon ecu - something I have to verify with VCDS.
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
