Page 16 of 20 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 198
Thread: Auto-Polar FIS+ Advanced - Complete Guide
  1. #151
    Jan 2012
    I MIGHT have an EOS in a few weeks I can play with, ill take some pics for you.
  2. #152
    Sydney,NSW
    Seems like we still have a a few "gaps" in the install guides.
    Anyone willing to do an install and write-up (take a few photos along the way) into a Passat, Eos or Scirocco I'll offer $10 off and free shipping.
    Cool! Someone will show me in person their polar fis. Then when I get the cash will install one on a passat since no one has done one yet.
  3. #153
    Jan 2012
    where in Sydney are you? I can show you mine
  4. #154
    Jun 2011
    Installing this thing is a pain in the ass... Trying on a MK6 Golf R from inside cabin... got the hex screw out which was a pain, the box the hex screw was holding in place - i'm assuming thats the one i need to get out to unplug? The instructions say there is plenty of wire on it so i should be able to just pull it out but it feels like the cable is pretty tight to me??? And without pulling it out I can't see how to unplug the cable on it...what is this box exactly that im unplugging?
    Edit so that wasn't the right box, the box that has the hex screw into it is just in the way for the box you really want behind it, which has the cable you need.... and that box behind the box with the hex screw is the one you can use the long flat head screwdriver to leverage out as the guide suggests... Fitting everything back in behind that console thing is also a bit of a pain, hope it wont rattle now...
  5. #155
    Yes the main challenge with installing the unit is to locate the CANbus interface and connect the piggy-back cable in.
    Once you've done this the rest is straight forward in comparison.
  6. #156
    Jun 2011
    So what exactly are the 2 boxes for? The one that has the hex screw that is in the way, and the one i'm actually piggybacking onto?
  7. #157
    Quote Originally Posted by Ferni View Post
    Not sure what the other box you had to move was, however the one you plugged the cable into is the CANbus gateway module.
    See here for description of what it does: CAN bus gateway removing, installing and upgrading - Volkswagen Golf
    Essentially you're connecting into the infotainment bus and getting access to the all the diagnostic data that is available on all the various busses running around the car.
    Nov 2005
    Sydney NSW
    I tried to do the same as you - install from inside. And I got stuck as I had 2 controllers up behind the fuse box. I got the fist box out of the way but ther no way I could get my fingers further back to unclip the canbus cable. In the end I went through from under the windscreen and it was soooooo much easier and there was heaps of room form accessing the cable and putting in the FIS harness.
  9. #159
    Jun 2011
    So today started the car and no Phone menu and no AutoPolar menu in sight on my MFD..... tried holding down OK button for 10sec but no luck... any ideas? Do I need to pull a fuse or something? Or will it fix itself?
  10. #160
    To turn the unit on (after you've turned it off), you need to hold the OK button for about 30 seconds.
    I would suggest that if you haven't turned it off, you'll need to pull the fuse - F24 on Golf6. Otherwise either pull the unit off it's connector (if you can access it easily) or disconnect the battery for 30 seconds will also work.
    Recommend not leaving it as you could end up with a flat battery as likely your radio won't turn off if the autopolar isn't working. FIS+ won't pass through other comms on the infotainment bus if it's not working and therefore your radio won't get the message to switch off.
    Other thing is to check the physical connections are still OK.
