I thought a few peiople might be interested in the 0.3.5 update as there's quite a few new features been added:
***** Improvements / Update description for RED cluster *****
[+] Added +1 new parameter : Load specified by ECU
[+] Improved Climatronic emulation.
[+] Added support for all brands in Parktronic OPS emulation
[+] Added Parktronic screen in FIS. To activate go to Polar FIS configuration menú and then CONFORT->PARKTRONIC FIS. Enabling it, when you activate the Parktronic, if you+re showing the Polar FIS main screen, it will automatically change to a screen which shows the value of parktronic sensors.
[+] Added Factory reset in Polar FIS configuration menu
[+] Improved compatibility for white dot handsfree ecus with Seat steering wheels.
[+] Portuguese texts improved.
[+] Improved text of parameter FUEL LITERS, now indicated Gallons or Liters.
[+] Improved intake temperature reading.
[+] Added one touch opening. to activate go to Polar FIS configuration menu, and then CONFORT->ONE TOUCH OPEN.
[+] Added auto closing windows.. to activate go to Polar FIS configuration menu, and then CONFORT->AUTO CLOSING. Enabling it, after passed the programmed time from car closed, the windows will close automatically.
[+] Added support for engine ecus: 5L0-907-115-D and 03H-906-032-GF
[+] General software stability improved
***** Improvements / Update description for WHITE and COLOR cluster *****
[+] Improved mirror lowering function in automatic mode
The two new Parktronic functions include:
1) Parktronic in Fis (no need for RNS510)
2) OPS in RNS510 All Brands not only Skoda
Here's a video of the first function to see how it works:
