Page 9 of 20 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 198
Thread: Auto-Polar FIS+ Advanced - Complete Guide
  1. #81
    Apr 2010
    They're mirrors, silly
  2. #82
    Jan 2012
    Window dipping in automatic mode only works when you have the indicator on i.e. when reverse parallel parking.
    I haven't played around with the trim much. The offset changes the position the mirror returns to. If you find it returns too high/low you can adjust the return position up or down using the offset value.
    ahhh indicator and reverse is 'auto'! thank for you that. ill set mine to auto
  3. #83
    Quote Originally Posted by zei20t View Post
    Yes it doesn't matter where your mirror selector switch is set (so I believe). As soon as you have reverse gear and your indicator going the mirror will dip.
    I'm using manual mode as I find it useful to have the mirror dipping when reversing out the driveway.... and I don't want to have the indicator on while doing this
    Aaaaahhhh yes good pick-up
    I'm still trying to get the auto window closing function going though.... tried a couple of times but no success.
    Apr 2010
    Isn't there a normal MFD setting for that - or it's at least available via VCDS. I prefer to have manual control by holding lock/unlock on the key fob (i.e I'll often get out of the car, hold unlock to open all windows a smidge, then lock the car).
  6. #86
    Dec 2012
    Sutherland Shire, Sydney
    Yeah - that does not work for me at all - hence using manual mode at present
  7. #87
    Dec 2012
    I do that also - they are always closed when I return to the car after work
    (This is prior to installing the Polar FIS)
    I love using the key to fully open the windows before reaching the car - really useful
    Hate openning the door and getting a blast of hot air
  8. #88
    Apr 2010
    Same here - I time the window opening just as someone else is about to walk past to freak 'em out
  9. #89
    Dec 2012
    My cat jumped into the car, I remotely closed the window
    The look on it's face looking out of the now closed window was priceless (what am I gonna do now?)
  10. #90
    I was talking about auto-closing on sensing rain.... not cats
