Was browsing through my Gmail spam and saw an email for a thread update on the AutoPolar forums. Clicked it, and Google complained that the website now contains malware. Anyone else getting this?
I would only assume it's to do with the uncertified ActiveX control on the update page (which wouldn't even work in Google Chrome anyway).
The Website Ahead Contains Malware!
Google Chrome has blocked access to Autopolar Official Web site for now.
Even if you have visited this website safely in the past, visiting it now is very likely to infect your computer with malware.
Malware is malicious software that causes things like identity theft, financial loss and permanent file deletion. Learn more
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
Yes Auto-Polar updater only works with ie not chrome or Mozilla. And yes have to enable unsigned active-x.
I updated last week with no issues.
Google warnings don't have anything to do with local antivirus on your PC.
The warning is gone now anyway, maybe their certificate expired and they've just replaced it with a new one.
This photo from Transporter, Golf MKVI, is very similar to what you will find in the Skoda Octavia II 2011/2012
Note however, the gateway cable has a security lock and it's on the back, tricky
The 3.3 firmware did not work with my Octavia - upgraded to 3.4W and all good
However my VCDS no longer works (cable does get a green LED - still looking into this problem) even when I turn the Polar FIS off
Thanks mate - you're absolutely correct - the problem was my VCDS
I'm running V12 which is beta - it was saying the software is "out of date" on startup, but it's not connected to the network so I assumed it was time limited - I've upgraded to the latest V12 beta and everything is working now (phew!)
Now - to configure the screen contents to display
Screen 2 is almost impossible to scroll to, get's skipped 7 times out of 10
I am also having problems with the window dipping feature despite reading/watching info - will try again
Update: Window dipping in manual mode working (does automatic only work with the car operating?)
Does the trim alter the dipped or driving position???
Mirror dipping in automatic mode only works when you have the indicator on i.e. when reverse parallel parking.
I haven't played around with the trim much. The offset changes the position the mirror returns to. If you find it returns too high/low you can adjust the return position up or down using the offset value.
Last edited by tigger73; 23-02-2013 at 07:41 PM. Reason: correction for window dipping function :)
Window dipping?![]()
