Has anyone looked at using the bluetooth compatibility function yet? This is mainly for people with a red MFD and wanting to run the latest bluetooth units.
Here's some additional info on this function:
What is compatibility with hands-free OEM units?
This emulation allows mounting the latest BT for white MFD in a vehicle fitted with red MFD and to see the Phone menu in the MFD.
What are the advantages of BT units for white MFD?
The main advantage of later BT units is AD2P audio feature which lets you play music through the phone and listen through the speakers of the car radio.
Apart from this, the control units for white MFD are equipped with later chips and newer versions of software so that its operation is more stable and effective.
How can I enable this compatibility mode?
After entering the setup menu for Polar FIS, go to the menu DISPLAY-> DISPLAY-> EMUL. BT and then activate the function. After activated, the function is not available immediately as it needs to be enabled. You must turn off the vehicle and wait 1 minute after the screen goes blank in the MFD. From then you can restart the vehicle and the unit will now run correctly. This step is only necessary after enabling this function for the first time.
IMPORTANT NOTE : Polar FIS only performs the function of supporting the BT unit to create Phone menus in the MFD. All functions including Agenda, connection, audio AD2P ultimately depend on the compatibility of the phone and radio, as in the other ECUs BT, Parrot, etc.
Videos of compatibility of BT (working with red MFD)
NOTE : All videos are from a SKODA vehicle with red MFD (which is white just to confuse everyone).
(Basic BT Unit - Enabling the option)
(Basic BT Unit - Working)
