Three ways to reset the FIS+:
- Pull the connector off the FIS+ module and reconnect
- Pull the fuse (F24) from under the hood
- Disconnect the battery
I do the first as I have easy access to the module/connector.
If you ever have the problem where your radio does not switch off when you remove your key then you know that the FIS+ firmware has crashed.
If this ever happens, please make sure you reset the FIS+ and ensure radio powers off before leaving your vehicle as otherwise you may well come back to a flat battery.
Generally the later firmware versions are more stable (i.e. known bugs have been fixed). Though I am aware that some BT units can send commands/characters which upset the FIS+ (certainly used to be the case at least).
