Ok. I saw someone made a good suggestion on a split screen - a way to have a large number (selected gear) and two smaller, all on same screen.
Golf R | UG | DSG | 19" Silver | ACC | Leather | Viezu vRace | FIS+ Advanced | View car diary thread
Yeah the gear selector screen probably wouldn't be a bad idea.
Though as soon as you change the display set-up it means more configuration. Obviously the large display format can be done as per the current speed display in the "normal" MFD.
We'll have to wait and see.
Hi guys.. been following this thread. Can this be installed in a mk6 golf cabriolet? I am from singapore and haven seen much data on this polaris here.
Sent from my GT-I9300 using Tapatalk 4 Beta
I am almost certain if you have full height MFD this will work.
It works in both Mk5&6 Golfs with either red/white/colour MFD though must be full height. I don't believe there will be a major change in the electrics for the cabriolet so it should work the same.
If you want to be 100% sure, you can post a VCDS auto-scan on the Auto-Polar forum and the developers can determine from the hardware you have installed if it is compatible or not with your vehicle.
I don't think there is a cabriolet with an AutoPolar installed in Australia - mainly because there's not that many cabriolets!![]()
