Dude you should post it in the Audio section. Fire a PM to ICACHA for the info on CANBUS for the headunit.
Splits wont be a problem, mount the tweeters where you will get the best staging ( i.e. A pillars or kick panels ), often that is not in the factory slots
Just make sure you deaden the door for the mids and use an absorbant pad behind it. Are you going to amp them?
