Results 1 to 4 of 4
Thread: audi concert stereo query???
    sydney
    just doing the radio in the a3 and everything is good, power and so on but cant get any rear signal??plugged what i could trace to be the rears but nothing? there is a common lead(presuming negative)but also another lead the fifth of the group which has a +with a gate sign
    any ideas
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    sydney
    referring too #1236 line out in the lower right
    sydney
    answering my own questions here but may help someone someday,
    the four terminals are to run the amplified rear speakers,i ran them by connecting the #6 wire(white n grey from memory) to the amp/remote signal on the headunit and the speakers in the standard format,this works the speaker but with way to much gain,ie running full signal from the headunit plus the amps power.so what i need to do is connect these 4/5 wires to 2 rca and run them through the rca output on the headunit, or run straight speaker cables to the speaker and remove the factory amp
    i presume you can do this (the rca adapter) will check jaycar and so on tommoz
    sydney
    rca output was to low and direct connection to high so i just wired them directly to the headunit (removing the inline amp) and all is well,worked out really well, nice headunit
