Results 1 to 9 of 9
Thread: Antenna adapter for RNS510 on eBay ?
    Mar 2011
    Thanks Ian, ordered !
    Mar 2011
    Gold Coast QLD
    In reference to the options of converting the 2 x single
    FAKRA antenna cables from a 2nd gen RCD300 into a
    dual-FAKRA required by 3rd gen units like the RNS510
    (Details on maverick's site: Upgrading 2nd generation radios (RCD 300, RCD 500) to 3rd generation (RCD 210, RCD 310, RNS 310, RNS 510, RCD 510) antenna adapter | my-gti.com )
    Is it possible to snap off the plastic connectors from
    the 2 x single FAKRA wires in the car, and insert the
    metal SMA plugs into the dual-FAKRA plastic connector
    bit from the $40 adapter, even if the SMA plugs are
    the 90' degree swivel type?
    On the photo of the $40 adapter it looks like the
    dual-FAKRA end has 2 x 90' degree swivel SMA plugs
    inside.
    This way I would avoid any signal loss from having the
    in-line connections, but have still adapted the wires from the
    old single-FAKRA housings to the new double-FAKRA housing.
    See my mock-up image: ImageShack® - Online Photo and Video Hosting
    Thanks for any advice!
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
    Dec 2008
    Sydney/Canberra
    I've got several of the kits Maverick has outlined as Option 1 that I'm selling.
    $23 posted Australia-wide. PM me if you're interested.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2011
    Gold Coast QLD
    Update: I bought the antenna adapter pictured above, and tried to put the original car plugs (without the plastic bits because I snapped them off) into the adapter's dual-fakra plastic case. Result = fail. The metal SMA plugs in the car are a difference shape and don't fit in the adapter's white plastic dual-FAKRA housing.
    Because using the adapter would cause a considerable loss of signal from the aerial, (by adding further interconnects, each extra connection causes reflection of signal and up to 3dB signal loss) I decided to just shove the SMA plugs into the back of the RNS510 without their little plastic cases. They hold securely enough, the SMA connectors are pretty good by themselves, not sure why the extra FAKRA plastic is needed in the first place......
