Page 123 of 149 FirstFirst ... 2373113121122123124125133 ... LastLast
Results 1,221 to 1,230 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1221
    Sep 2008
    Melbourne, Australia
    Yes, That's what I use. 4 and 2 Gb
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  2. #1222
    Will the Bluetooth voice audio (push microphone on steering wheel. snd say call dan) will this still work with the Ans 810
  3. #1223
    Mar 2008
    Chatswood, NSW
    Quote Originally Posted by bazzle View Post
    The one I linked 2 posts above is the best Ive found so far. It is also ccd and has a color display at night. Resolution and pic is very clear and more than enough for the 8" screen.It does have a set of distance lines but they match the ones in the ANS 810.
    Ive also been fitting these and they are an easier fit as they just swap out for a number plate light.
    CCD Reverse Camera FOR VW Beetle Passat Golf Polo Jetta Phaeton Skoda Superb | eBay $18
    Pic is preety good as well.
    How easy are these to install? I might attempt it when I have some free time, I'm guessing running the av cable from the ANS to the rear bumper will be the hardest part, does the camera require power? Cheers
    MKV GTI
  4. #1224
    Aug 2013
    Eastern Subs, Sydney
    Sorry if this question has been asked before, but I couldn't find an answer.
    Can play spotfiy on these units via my iphone? Even if its just through a 3.5mm aux jack or a bluetooth audio stream?
    Edit
    Ignore me. I found my answer here:
    Quote Originally Posted by DkN View Post
    I'm not sure about USB 3G capabilities but I don't think the unit currently supports it - however it does stream music via BT fine so you can listen to internet radio that way, a customer of mine does this and says it works well.......
  5. #1225
    Sep 2008
    Just run camera wires along and under left door sill trims etc.
    Power can be picked up off ANS or wired to cig lighter etc depending on model.
    Rev signal is supplied by later units. Early ones you run a trigger wire from rev light.
    Dash isn't too hard to open. Plenty of tips on VW forums.
  6. #1226
    Just to confirm (since i'll be doing this when I get my DNS), the units have both video in for the RVC, a reverse signal wire and you can easily tap off the 12V supply line for it too? So when you pull the wires up to the front you'd have Video, Power and Reverse wires? As opposed to tapping off power and the reverse signal from the rear lights, and just bringing video up to the front?
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  7. #1227
    Jun 2011
    Quote Originally Posted by raymondtrudeau View Post
    There is no voice control for the DNS unit so that wouldn't work. However you can use the DNS (not ANS) unit has memory bank like the RNS-510 so you can push your phone button on the steering wheel and just press one of the 6 available memory banks.
    Quote Originally Posted by moda View Post
    The unit has the power wire that the camera needs, which switches on only in reverse, as well as the video input. You don't need to tap any 12V supplies except the one to power the actual LED with (not the camera). On some licence plate style cameras, like the one for Golf 6, there is no LED and instead there is a compartment to fit the OEM bulb inside so you don't even need to do that - you can leave the OEM bulb and its connection intact.
  8. #1228
    Groovy, cheers
  9. #1229
    Aug 2013
    Casablanca
    Quote Originally Posted by Martin Thiesen View Post
    Hi DkN
    I have now flashback to the previous MPU.
    The Firmware information is now:
    Version:
    BSP: ANS510AS.611
    MPU: ANS510AS.M93
    MPGE :
    Servo :
    MCU : ANS510AS.121123.m1.D1
    BT : 20120405
    MST701: 6.2.01
    Region code 9
    Without any luck still the same problem.
    Can the problem bee that something did go wrong when i updated the mpeg?
    Do you have any suggestions for what I can do?
    Hi Martin Thiesen
    I have the same problem with my ANS510. I think i have installed a bad version that i found on the internet. A part of this update is done by media slot (MPEG) named ANS510AS.XF14. I contact audiosources to have the latest version of my ANS510, I done it but i have the same problem. media sdcard, CD/DVD and USB port doesn't work. In the update that i had from audiosources there is no ANS510AS.XF14 just the BSP, MPU and MCU.
    Did you found a solution,
    Dkn can you help me please
    My actual version:
    BSP: ANS510AS.612
    MPU: ANS510AS.M99
    MPGE :
    Servo :
    MCU : ANS510AS.131012.m1.T0
    BT : 20120512
    MST701: 7.0.098
    Region code 9
    Sorry for my bad english
  10. #1230
    Jun 2011
    Sydney NSW
    Vehicle Graphic LHD/RHD
    G'day,
    I have an ANS-610 and only just noticed after the last firmware update that the graphic on the touch screen to indicate which door is open is reversed. It appears to be set for LHD vehicles as when I open the driver's side door, it shows the passenger's side door as open. How do I set it for RHD vehicles?
