Originally Posted by
tom_12_24
Will the new DNS-710 use the same 26 pin connector like the OEM RNS510 for reversing camera et al? Or will an an adapter to RCA be required?
Thanks
No it will continue to use RCA connector so that it is more compatible with aftermarket cameras. If you ask me 26pin RGB for a camera is ridiculous - connectors like FAKRA make sense because of quality but the RGB connector does not. Audiosources have had a 26-pin to RCA converter module for some time now though, so you can connect your factory camera to the ANS / DNS units.
