Page 115 of 149 FirstFirst ... 1565105113114115116117125 ... LastLast
Results 1,141 to 1,150 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1141
    Mar 2013
    Amman - Jordan
  2. #1142
    Sep 2008
    Melbourne, Australia
    Quote Originally Posted by Na2eL View Post
    29-5-2013
    August 2013
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  3. #1143
    Mar 2013
    Amman - Jordan
    Quote Originally Posted by bazzle View Post
    August 2013
    i will get ANS-610 then </3
  4. #1144
    Dec 2012
    Michgan, USA
    Quote Originally Posted by Idle View Post
    As DkN has already pointed out, your immediate need is to find out why your reverse line is dead and rectify it.
    No power always equals no go.
    A VCDS system scan might reveal where to look.
    This has been what is frustrating. I can't figure out why I lost power at the right rear reverse wire. I don't see a blown fuse. I have run VCDS and don't find anything that points out an issue. I even tried to change the coding for the lighting in case somehow the system changed a bit/byte setting. No help with using the common lighting setting changes common to those who have either installed LED and/or fog rear lighting.
    Like I mentioned I have taken a break. My next ideas are still to investigate whether there is a VCDS coding change that could help activate this rear reverse power line. Or, perhaps during my wiring it led to a short somewhere in the wire....who knows where...I hope it isn't this.
    Thanks for the feedback. I'll have some more time to work on it this weekend. What really confuses me is why there is no bulb warning light since the right rear reverse light is not active....makes me think there still could be a VCDS setting that will magically reactivate power to the wire in question....I can only hope.
    Paul.
  5. #1145
    Dec 2009
    Kew, VIC
    Quote Originally Posted by schultp View Post
    If you own the unit, a good place to look might be the VCDS forum — there's a wealth of information to be had there.
    It would be unusual for you to have shorted anything without having noticed it, and if you did, that's what fuses are for — have you identified and actually checked the relevant fuse (with a meter or light, just looking isn't always positive proof.)
    Also check the light bulb itself (and its ground,) and make very certain your new device actually works in a test environment.
  6. #1146
    Dec 2012
    Michgan, USA
    No one responds on the VCDS forums I have posted on (tdiclub site).
    Bulb and ground have checked out OK.
    Have never had anyone confirm which fuse is responsible. But, visually all look good and there is no other electrical outages and I assume the right rear reverse light would not have a dedicated circuit.
    I'll email ross-tech directly and see if they have any recommendations on VCDS tweaks.
    Thanks,
    Paul.
  7. #1147
    Jun 2011
    Update on the new generation unit
    I am going overseas next week and will be away until 27 June. By that time, the new unit should be ready for release. I am starting an EOI / waiting list HERE and encourage anyone waiting for the new unit to go there and make a post to express your interest.
    When I come back from the holiday I will go through the thread and add all interested people to the list and send a PM to confirm order and pricing. The first order will be put through as a group buy at discounted prices, and I will confirm what they will be when I return. The standard price is expected to be around $750-800 upon release, and I would expect around 10% discount, or maybe even more depending on numbers. Those who respond to me by 30 June will also receive an invoiced dated 30 June if you want to squeeze it in before the EOFY
  8. #1148
    Mar 2013
    Amman - Jordan
    The new DNS-810 will have power on top like the ANS-810?
    Stupid question but why do most people go for the ANS-510 and ANS-810, why not ANS-610?
    Thanks
  9. #1149
    Jun 2011
    Thanks
    Yes, the external front panel design will not change much.
    Regarding the popularity of the 610, that's just because I initially carried only the 810 and 510. In their domestic market in China the 610 is the most popular because it's about as big as the screen can get while still sticking close to the RNS-510 look.
    My personal preference has always been the 810 though, because you get a significant screen size upgrade and while it doesn't look like an RNS-510 it still looks perfectly stock and integrated with the dash. I'd happily bet that anyone who doesn't know VW head units will not be able to spot the ANS-810 as aftermarket.
  10. #1150
    Jun 2012
    Quote Originally Posted by DkN View Post
    Now for the big news.
    It will also have OEM style connection in the back - no more adapters, and this also means it will use the factory FAKRA antenna connection and therefore eliminate all radio reception issues.:
    Will the new DNS-710 use the same 26 pin connector like the OEM RNS510 for reversing camera et al? Or will an an adapter to RCA be required?
    Thanks
