Page 113 of 149 FirstFirst ... 1363103111112113114115123 ... LastLast
Results 1,121 to 1,130 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1121
    Mar 2013
    Greece
    Actually is the Golf V 2005.5 type buttons
  2. #1122
    Sep 2008
    Melbourne, Australia
    There is a hidden canbus selection menu, fogotten where, if you get to it you could try a diff setting?
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  3. #1123
    Mar 2013
    Greece
    OK Thank you, maybe Sandy knows how to access that menu. I have try changing the gateway with newer with no luck.
    I have the ANS 610
  4. #1124
    Jun 2011
    The hidden menu is accessed by long pressing the middle of the far left of the screen in Aux-In mode. However as I mentioned, while there is a CAN-Bus selection option, it does not appear to actually do anything. From what I understand the current ANS series have CAN-Bus decoder modules that cannot be upgraded via firmware, which unfortunately makes your steering wheel button issues unlikely to be resolved by an update.
    I would imagine that it's your steering controller that is sending different signals which are not interpreted by the ANS unit.
    the new generation units would have a CAN-Bus decoder that can be soft-upgraded.
  5. #1125
    any more news on those new units
  6. #1126
    Mar 2013
    Greece
    Quote Originally Posted by DkN View Post
    I tried 1K0 953 549 BK steering controller type 2 with no luck
    The only way to make it work (next-previous buttons) is when I set the MFD to AUDIO and through the wiper stalk arrows up and down.
    I didn't see any can-bus settings in my secret menu.
    The only reason that I'm still searching for a solution to that is because my previous RCD 300 MP3 was working fine with these type of buttons.
  7. #1127
    Aug 2012
    montrea
    Quote Originally Posted by alecocr20 View Post
    I just updated to:
    MPU: ANS510AS.M99
    MCU: ans510.130112.m1.D0
    FM station problem seems fixed but now I have a high beep sound when the unit is ON ( the beep was there before but much much lower)
    Alejandro
    I just realized that this beep noise ( is a background noise not the the key beep sound) is there when the brightness is medium
    When high or off is ok
    I don't know if all the units have the same issue
    Alejandro
  8. #1128
    Sep 2008
    I only use High. Next time I reset Ill have a look too
  9. #1129
    Jun 2011
    Alejandro
    When did you purchase the unit? I think I remember the technician mentioning that some earlier units had issues with audio feedback noise when the screen brightness is throttled.
  10. #1130
    Aug 2012
    montrea
    I bought it in september last year
    It's a ANS610
    Thank you
