Results 1 to 10 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
Threaded View
    Jun 2011
    Quote Originally Posted by dread1977 View Post
    Star DKN, thanks again.. im sure without your help most of us would be going mad with this unit!!
    I tried various AVI files last night converting them from mp4 to AVI but none worked, however reading about today ive discovered that AVI is just a container for the format of the video, so as per Audiousources advice im going to convert to MPEG4 as they advise, then covert to AVI and see if that works.. Ill keep the resolution down as I was wondering if that was stopping it from working..
    Oddly enough, some of the TV series I had on SD did work as AVI!! no idea what the differences are but im sure ill work it out.. may try Xvid or DivX and see what I get... Just curious, am i better doing this via USB stick instead of SD card?
    Thanks all
    There is no difference using SD vs USB, both use the same decoder chip.
    I recommend you use avidemux to convert your videos. Xvid and DivX are both MPEG-4 codecs.
    With avidemux, just choose one of the MPEG-4 codecs for video source, and for output leave it as the default AVI muxer.
