Page 109 of 149 FirstFirst ... 95999107108109110111119 ... LastLast
Results 1,081 to 1,090 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1081
    Dec 2012
    Michgan, USA
    I changed the grounding and there was not difference. I am now suspecting that I simply have another problem with the power line going to the right rear reverse light. There is no power to this line when I activate reverse gear. There is no break in the wire, all connections have been redone several times. I am thinking there is something centrally that has occurred. I still don't know which fuse is responsible for the right rear reverse light....anyone??
    Here is my update of the wiring I have done to date:
    Paul.
  2. #1082
    Dec 2012
    Michgan, USA
    Well, I tried to use my VCDS software to change some lighting settings to see if somehow my ECU had altered its behavior. I know that outside of North America that some countries only have one side reverse light and the other side a fog light. I thought that perhaps somehow it had gone to a non-NAR setting. I tried manipulating byte 18 in the Central Electronics Module but no change. This is the byte that a lot of folks manipulate to add a rear fog light and/or change to LED lighting.
    What is more aggravating is that once in a while when I first start the car I get a brief RVC screen on my ANS-810 without any image. After a few seconds it flips to the radio screen.
    Paul.
  3. #1083
    Jan 2012
    Epping, NSW
    Re: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
    Are you saying your reverse light doesn't work? If it works, it could be switched in 2 ways.
    1. 12v always on it and ground is switched when going to reverse (relay setup would have to change). Or
    2. Permanent ground on it and 12V switches to it (relay setup is probably ok if connected to non ground side, test with multimeter with globe removed).
    Sent from my GT-N7105 using Tapatalk 2
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
  4. #1084
    Dec 2012
    Michgan, USA
    Reverse light doesn't work on the right side.
    I've checked with my multimeter. I am fairly certain that the 12V reverse light power is switched since this is how the left reverse light operates as confirmed by testing. And the wiring connector at the rear light assembly has 4 power lines and only one common ground wire. This would go against a switched ground wire as all lights in the rear light assembly would then be under the influence of that one switched line.
    Paul.
  5. #1085
    Pacific Paradise QLD
    Quote Originally Posted by schultp View Post
    Paul.
    Why dont you run a wire straight off the 12v socket to the camera temporarily and see if that works Then you will know if its in the rev light wiring or not
  6. #1086
    Jan 2012
    Epping, NSW
    until you get the light feed fixed, you won't see the camera..I don't know if the relay load will influence the CAN monitoring? Time to go through your fuses ( has the right reverse light ever worked)? here in Australia we definitely only have a left rear reverse light though).
  7. #1087
    Dec 2012
    Michgan, USA
    I will get around to doing this but since there is no power going to the reverse light itself I want to get this working before tackling the camera. I suspect that if I get power going through the reverse light power wire that the camera issue will also resolve itself.
    Quote Originally Posted by tonymy01 View Post
    I agree totally. Others on this forum have used the reverse light power feed to trigger a relay. I am hoping that others who have succeeded will chime in and either correct my wiring diagram or confirm I am on the right track. If my wiring set-up is found to be sound then I definitely feel that there is something going on "centrally" either a fuse (which one handles the reverse lights??) or a ECU setting.
    Thanks for all the input...keep it coming!
    Paul.
  8. #1088
    Jan 2012
    Epping, NSW
    your wiring looks fine, assuming the relay isn't loading up the system and causing probs. but has your right rear reverse light ever worked? I assume you have modded and put LED rears in, did you check that was all fine?
    ( as was suggested, use your 12V feed to test camera, and if you don't have a right rear reverse, take it off left rear instead ).
  9. #1089
    Jun 2011
    Most recent firmware update went out tonight - let me know if anyone subscribed did not receive it, I recall a couple of bounces in the emails.
    Latest available firmware is also now listed in the second post of this thread.
  10. #1090
    Feb 2013
    Spain
    Any news about new units?
    I'm happy for the users of the ANS810, so they are still getting new firmware updates.
    By the way, Mirrorlink is a registered standard. When I saw that the new unit would come with Mirrorlink I thought it would be that. Anyway, it's a cool option (but there are several far importants for me).
